Results 1 to 2 of 2
Thread: Using Flashscan to tune 07 trucks w/DOD & AFM
    May 2006
    Default Using Flashscan to tune 07 trucks w/DOD & AFM
    How does Displacement On Demand and Active Fuel Management effect programming the PCM: ECM/TCM? I'm going to buy a new Silverado and am wondering if I should get one of the ones they are calling "Classic" Silverados(Legacy) or opt for one of the new types that has DOD and AFM. The newer ones have a faster CPU and more running memory to deal with these new features, but I don't belive you'll be able to install an aftermarket cam in them because of the special cam lobes and complex lifters they use to shut 4 cylinders off.
    Jan 2005
    Changing camshafts shouldn't be a problem provided you don't get too crazy on lift and duration (which you probably won't, considering it's a truck). The lifters should be compatible with an aftermarket cam, and they're what control the valves. The only question is whether there are any cam machining considerations that pertain to oil flow. I don't believe there are, but I'm sure someone in the tech department at Comp Cams or other cam manufacturer could supply a definitive answer.
    By the way, this should be in Gen IV specific section.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
  1. FlashScan V2 Scan and Tune is it comercial too
    By nycblazer in forum Gen IV V8 Specific
    Last Post: January 24th, 2008, 01:31 AM
  2. Save tune from PCM. Have FlashScan and a RR PCM about to go in
    By WestSide in forum General (Petrol, Gas, Ethanol)
    Last Post: August 11th, 2007, 09:09 PM
  3. 07 trucks
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: June 24th, 2006, 05:47 PM
  4. FlashScan Tune - Register PCM Error
    By highperf in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2005, 11:41 AM
