Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: How Do I Create a Map of C6101?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Red face How Do I Create a Map of C6101?
    I am doing a VE/MAF tune and bumped C6101 by 20%. I thought I could just copy the columns/rows from C6101 into EFI Scan and see similar readings. The columns representent RPM and I set rows to SAE.TP but this is obviously not right. All data is being logged into first row.
    My thoughts are I could monitor this and make adjustments once I go back to CL/MAF!
    Any suggestions?
    TIA
    2015 Z06 A8
    Oct 2004
    The units for that table in my tune (and metric ) is "Milligrams per cylinder". There is no PID that uses that as units so you would have to create a calculated PID yourself to resolve that.
    The row and column stuff should be easy. My bet is that you actually don;t have SAE.TP selected in your PID list. IIRC you had ETC TP cause I asked you why it was at 12% cause I forgot it was a Vette with ETC
    Andrew
    EFILive Crew
    Sep 2003
    I have been trying to create my own pid but directions are a bit murky. I know that I have to start with the calc.pid in User config. Paul's example seems different from what I am trying to do.
    Do I have to save the file with a new name or will that be done once I complete the file?
    2015 Z06 A8
    Sep 2003
    BTW I do have a SAE.TP
    2015 Z06 A8
    Oct 2004
    File will be called 'calc_pids.txt' like it is now - that filename is correct. To get an idea of the format of the different sections have a look at the 'sae_generics.txt' file in 'C:\Program Files\EFILive\V7\Configuration' folder.
    Andrew
    EFILive Crew
    Sep 2003
    Might be easier to copy paste data to Excel and multiply by 1000, add 20% and paste back into the tun .
    2015 Z06 A8
    Oct 2004
    Didn't you already add 20% to the table? If you just want to add 20% that is easy and can be done without anything flash
    Andrew
    EFILive Crew
    Sep 2003
    Yes, already added 20% fro tuning. My thoughts were that after tuning I could reset C6101 with newly adjusted numbers which would more closely resemble actual flow numbers after tuning.
    2015 Z06 A8
    Sep 2003
    Trying to create my own pid. Where do i get the prn and slot data? ANyone tell me what I did wrong?
    File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    mgcyl None "mg/cyl" "Milligrams/Cylinder"
    None None "" "No units"
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units Low High Fmt Expression
    MG_Per_Second 0 1000 .1 "{GM.DYNCYLAIR_DMA} * 1000"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.gms_Per_MS F001 GRAMS All
    2015 Z06 A8
    Code:
    # File details
    *FILE
    # Units
    *UNITS
    mgpc      Metric     mg/cyl   "Milligrams per cylinder"
    *CLC-00-000
    mgpc                    0.0        2000.0   .0 "{GM.DYNCYLAIR_DMA}*1000"
    CALC.DYNCYLAIR_MG          F500 CLC-00-000   mgpc             Tune             "Air Flow Milligrams/Cyl - Speed Density"
  1. Replies: 41
    Last Post: August 13th, 2014, 01:54 PM
  2. P1514 vs C6101
    By bobbycollier in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 14th, 2008, 11:46 AM
  3. Mapping c6101 in scantool to adjust in tune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 06:30 AM
  4. Replies: 8
    Last Post: February 27th, 2005, 02:24 PM
