Results 1 to 5 of 5
Thread: RPM calculator
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default RPM calculator
    Has anybody noticed that the RPM calculator per gear at the bottom of the screen only shows N/A for the T42 trans files. Is this going to be a future update or is it not possible to implement on these files.
    It may be implemented in future. The problem is that when the trans *.tun file is loaded EFILive does not "know" the diff ratio, so it can't calculate the engine RPM for the given speed.
    What we will probably do is allow the user to enter a diff ratio that will be used to calculate/display the engine RPM.
    Edit: Looks like the diff ratio is in there as {D7007} - look for the update in the next release.
    May 2005
    As everybody has said before "ask and you will recieve".
    Top stuff, will save me having to put numbers into a gen 3 file to get some figures.
    I think I have the same issue with my TrailBlazer LL8 I6 with the 4L60E trans, always get 0s down there.
    May 2005
    I was just going to put the numbers into a gen 3 tune with the same tranny & diff ratios and then copy , paste the numbers to the T42 tune.
  1. Speedo-Calculator ?
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2014, 10:32 AM
  2. LMM Speedo Calculator
    By Redline Motorsports in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 28th, 2008, 06:51 AM
  3. need help with SPEEDO CALCULATOR
    By Boost in forum General (Diesel)
    Last Post: October 17th, 2007, 01:09 PM
  4. EFI shift calculator
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2006, 03:32 AM
