Results 1 to 7 of 7
Thread: How to Setup DFCO for Economy?
    Member neil's Avatar
    May 2006
    Default How to Setup DFCO for Economy?
    How do you setup DFCO for increased fuel economy?
    Is it possible to turn it completely off or do you need to adjust the tables to achieve this?
    Neil.
    Oct 2005
    I lowered the RPM points so its enabled pretty much any time Im off the throttle. It jerks a bit when it exits at real low rpm, but thats cool, reminds me Im saving gas
    Also zero'd the delay value.
    2014 VF SV LS3 Maloo.
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    The LS2 DFCO is quite different - any ideas. Answer in the Gen IV section
    Oct 2006
    What effect do b3334, b3335, and b3336 have on DFCO, when it is enabled? Can you play with these to gain a little more DFCO active time? Thanks, Mo.
    1999 GMC Jimmy 4.3
    Lifetime Member limited cv8r's Avatar
    May 2005
    I believe that b3334, b3335, and b3336 are there to allow DFCO to transition smoothly between being active and not. I think that b3314,b3316,b3318,b3320 will have a far greater effect on DFCO active time.
    Lifetime Member Boost's Avatar
    Dec 2006
    What is DFCO?
    8.7 @ 84 (1/8 mile) bolt-ons
    Deceleration Fuel Cut Off
    (Its ok, I learned what it meant here too)
  1. E38 Economy techniques
    By macca_779 in forum Tuning For Economy
    Last Post: January 20th, 2011, 01:02 PM
  2. E38 economy and tweaking AFM
    By harascho in forum Tuning For Economy
    Last Post: February 14th, 2009, 08:48 AM
  3. TM bad for good economy?
    By N0DIH in forum Tuning For Economy
    Last Post: March 5th, 2008, 03:44 PM
  4. Improved economy through shifting?
    Last Post: August 22nd, 2007, 07:03 AM
  5. LPG economy tuning
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: August 21st, 2006, 10:59 AM
