How can I log
I have recently purchased and installed the commercial version of EFILive. I'm running version 7.3.3 of the tuning software. I can flash the car but I can not figure out how to log infomation from the car. I can not even get the dash board on the software to indicated the status of the car.
I'm sure this newbie is missing something simple. Can you help?
2001 Z06
Rusty,
If you can flash the PCM then your 90% of the way there.
Close down EFILive Tune, open up EFILive Scan Tool...plug flashscan into PC and Car, turn on Ignition, push the little green button at the top left of the screen (just under "file") - that should get you connected. Then press F10 to pop up the dashboard (you want dash A for the guages view).
Rgds
Jim
You don't, of course, have to close Tune down...just makes it clearer.
Hmmm
I am 95% sure that I did those steps. I will start over from scratch and see if it helps. Thanks for the reply!
Welcome to the forum Rusty.
With the scan tool open, press the green button (or ctrl+F3) then at the bottom center of the scan tool, press the red button (or F3) to start logging. If you are only monitoring data (ctrl+m) the live data will only be visible on the data tab (F9)
Second Try
Happy Jim & TAQuickness,
Thanks for the steps to follow. I was able to get it connected for a short while. Here is what happened:
First Attempt: Car was running, clicked green button and successfully conneted to car. Clicked red button and started to log (frames started increasing in buttom corner). The dashboard was displayed since the beggining but RPMs and all other gauges is dead. Then I got a error box. Reconnecting.. Went to about 40 tries then error message stated no interface cable. This whole process was about 30 seconds long.
I confirmed proper cable connections and noticed that the obII LED on the inface box was flashing like it was still receiving data from the car. I removed all cables and reconnected but no success.
Second Attempt: I disconnected the battery and reconnected the battery. Connected all cables. Shut down and restarted scan tool Turn key to on. Clicked green then red button. (Car is not running) Started to receive frames as before. Then the same error message about no connection to interface cable.
Any ideas?
Simple stuff first:
Do you have PID's selected?
Off the wall stuff second:
Does the engine run otherwise?
When you're driving do all the guages run/work properly?
Does your cigarette ligher work?
Have you pulled the heads or engine recently?
TAQuickness:
Do you have PID's selected? I have mated my cable to the vin number but not really sure about selected PIDs.
Does the engine run otherwise? Yes
When you're driving do all the guages run/work properly? Yes
Does your cigarette ligher work? Yes
Have you pulled the heads or engine recently? Replaced this engine 10 races ago. Car is for track use only.
Two things come to mind,
1) On the PID's tab, make sure you have selected PID's to log.
2) Double check the grounds on the back of the left head. If they are loose, it will interupt communications on the bus and can cause the FS to disconnect. A common symptom of the grounds being loose is the intrument cluster "freaking out" under hard acceleration an corning. BUT, this symptom does not always occur.
TAQuickness:
I am going back to the garage and I will try what you suggested. Keep in mind that I am not driving the car. I have a laptop on a cart connected via USB to the interface mod which is connected to the car. I will be back in 1 hour.
Thanks for all your help.
Results
Ok.. Another failed test. I do have the ALL selected on the PID tab. It seems to have similiar results when I click monitor or log buttons at the bottom. This time I monitored the data tab and start to log. No data showed up. After 700 or so frames it came up with the reconnecting message which just increase retry number. Never does reconnect.
Does anyone have a tech support number?
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
