Results 1 to 8 of 8
Thread: High Oil pressure
    Dec 2006
    Default High Oil pressure
    Hey guys, was driving out to the beach this morning and about 20 mins into my trip my oil pressure started to rise and continued to rise till it got to about 700kPa and then my engine lamp came on on my dash. When i got to the beach with just normal driving with one or two stabs I had my max oil pressure around 900 kPa.
    Driving around yesterday it never rose over about 300-400 so I am confused to wat has caused my oil pressure to rise so high.
    On the way home it was around 800 kPa then froze at 897 kPa and didnt change for the rest of the trip!!!! I dont know whether this is a genuine oil pressure problem or the pressure sensor was on its way out and now has stuffed up???????
    I checked my DTC's and it gives an oil pressure fault (See attached images)
    I change my oil every 5000km/s and only use castrol edge fully sinthetic (spelling) so i cant see how the oil itself is a problem as it is very good oil (and expensive).
    Any Ideas?
ID:	1153   Click image for larger version.
    Jan 2005
    Seems like you had a clot or the sending unit could be on the way out.
    Dec 2006
    Its still a have not a had unfortunately. Ill change my oil 2morro and see how that goes but I dont like the way its going
    Oct 2003
    The sending units are known to fail.
    PowrMax Performance
    100 mm PowrMAF
    Oct 2005
    Very unlikely that there's anything wrong with your engine. This is either the sending unit itself or an electrical connection (ground). If you've been changing your oil every 5K and using oil that meets the SAE specs it's not likely a bearing failure.
    Dec 2006
    Yeah ill have to sus it out, thanx guys. Anyone know where they live in the engine?
    Oct 2003
    On the LS series stateside, it sits on the rear of the valley cover close to the firewall. Having one fail and give either high or low reading is almost normal. As long as your engine sounds normal there is a 90% chance that is the problem.
    Be happy.
    PowrMax Performance
    100 mm PowrMAF
    Dec 2006
    Yeah its giving a high reading. I turned the ignition on in my car and checked it without starting it and it was reading the same so i dare say the sensor is stuffed.
  1. Cant get high fan with a/c
    By lowws6 in forum Gen III V8 Specific
    Last Post: August 31st, 2010, 06:03 PM
  2. High IAC count?
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 20th, 2009, 08:05 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
  5. High/Low Spark Map
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2006, 08:27 PM
