Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: RR licenseing
    Oct 2004
    So that is nothing to do with RoadRunner then .
    Did you enter the details from the blue license card correctly? If you haven't entered these correctly (or at all) then it will stay in DEMO mode.
    Andrew
    EFILive Crew
    Jan 2007
    let me doble check on dat but can u explaind wats the rr and wat does dat du
    Oct 2004
    You posted in the RoadRunner section so I just assumed (as did others) that this was your problem. The RoadRunner is a replacement Real-Time PCM Emulator developed by Craig Moates.
    It allows changes to applied to the PCM immediately, without needing to stop, flash, restart etc.
    Andrew
    EFILive Crew
    Oct 2005
    i am having the same thing
    what can i do ?
Name:	New Picture.JPG
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    I don't understand what problem you are having assami. Can you tell us the vehicle you are trying to flash as well as the tune that you are going to put in it?
