Results 1 to 4 of 4
Thread: Dual Spark Maps - Difference ?
    Default Dual Spark Maps - Difference ?
    Hi all,
    I've gone over to COS3 now, however I can't seem to make sense of the difference between High and Low spark maps by looking at other stock GM tunes.
    In simplistic terms would I be safe in sorting out my high octane table and then copying that to the low octane table and applying a minus % figure across the board?? if so, would 15% sound a sensible margin?
    Any thoughts?
    Jim
    Oct 2004
    Do you understand the way the High and Low octane tables work?
    If not THIS POST explains it a bit
    Andrew
    EFILive Crew
    Lifetime Member johnv's Avatar
    Jan 2005
    Just use the factory low octane table,
    as long as you tune the High octane table so your not seeing any knock retard the table will not be used, but will give a safety net if you ever need it - (have to run lower octane fuel or get a bad batch of gas etc)
    I'm happy with what it's there for, and how the COS makes it work (and allows us to force the issue if we want).
    What I don't get is where the lower table should be, as the stock tunes are...er...varied to say the least.
    To make it simple, imagine your high octane table was a flat 38 deg across the board, what should the low octane table be set at? (cell minus Xdeg, or cell minus Y%).
    I quite like the idea of having a safety net in case I pick up a tank full of duff fuel, and I don't feel like leaving it where it is given that my high octane table will be tweaked all over the place (once I get going).
    Jim
  1. Dual spark map question???
    Last Post: August 10th, 2006, 06:31 AM
  2. Dual spark maps, let me get this straight????
    By nitrorocket in forum Custom Operating Systems
    Last Post: August 9th, 2006, 11:16 AM
  3. Question about Speed Density and dual spark map
    By agreif in forum Custom Operating Systems
    Last Post: May 6th, 2006, 08:37 AM
  4. Dual spark maps SD mode
    By APE346 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2005, 01:11 AM
  5. Twin Spark Maps?
    By BlownAlaskan in forum General (Petrol, Gas, Ethanol)
    Last Post: May 18th, 2005, 08:18 AM
