Results 1 to 5 of 5
Thread: Copy and Paste
    Aug 2006
    Default Copy and Paste
    Today I finally got up the nerve to install a COS. I am not sure how to Copy and Paste my initial tune parameters into the new 2bar tune. Where should the cursor be when I copy from and paste into the new tune ?
    Oct 2004
    When changing to the COS are you also changing the OS year (i.e. from say a 2000 to 2002)? If the stock and COS are related you can just follow the COS tutorial and cal flash in your current parameters.
    As for where the cursor should be the obvious answer is on the data which you wish to copy. So ordinarily you would select one or more cells and copy them, then select those same cells in the other tune and paste.
    You can also select the required cells and "copy with labels". In this case when "pasting with labels" into the other tune it doesn't matter what cell is selected as the label data takes car of that
    You can select an entire row or column by clicking on the header for that row/column. You can also select an entire table by clicking in the top left corner where the x and y axis meet, or press the CTRL+A shortcut key combination.
    Hope that helps,
    Andrew
    EFILive Crew
    Aug 2006
    Thank You, My biggest problem when it comes to computer stuff is that I AM CHICKEN. I need to get over that and just do it.
    Oct 2004
    There is always the Undo function (CTRL+Z shortcut)
    Andrew
    EFILive Crew
    Aug 2006
    Entire Table is what I was looking for----Thank You
  1. cant copy and paste with 7.5
    By articSS in forum Gen III V8 Specific
    Last Post: October 7th, 2008, 12:18 PM
  2. paste and divide...?
    By mr.prick in forum Tips and tricks
    Last Post: November 12th, 2007, 04:56 PM
  3. Can't paste into F0101
    By Cougar281 in forum Duramax LLY
    Last Post: October 8th, 2007, 02:33 AM
  4. Calibration cut and paste
    By Dynotuner in forum Gen III V8 Specific
    Last Post: September 27th, 2007, 12:57 PM
  5. Do we have a copy and paste feature
    By Dirk Diggler in forum General
    Last Post: February 20th, 2005, 06:49 PM
