Results 1 to 10 of 16
Thread: Autove tuning tips
    Apr 2006
    Default Autove tuning tips
    I am sure everyone has there own little tips and tricks they do apart from what the tutorial says while doing there Autove tuning, anyone want to share there own little secrets that make for a more consistant and acurate tune? I have been tuning the car for a while but still have spots that spike lean or rich mostly as I let off and back on the throttle....the crazy temps here are alo giving me a hard time....one day I got it next day I dont.
    I know weather and temp play hell on consistancy anyone ever put a resistor in the AIT sensor to eliminate heat soak and temp differences while tuning?
    what about special filters that you put in place aside from the one in the tutorial?
    99 C5 6speed LS2 402ci DTE 3.90 diff w/hardened output shaft, FLP headers, No Cats, ZO6 mufflers, Haltech Cobra CAI, Ported Fast 90 and LS2 TB, 42 Delphi, ZO6 Maf, EFI-Live, LC-1 wideband, Comp XE-r 232/236 .598/.605 112+0 lsa, AFR 205 heads milled .036 w/ Cometic .045 gaskets, TR 7.4 pushrods, textrila clutch, ASP underdrive pully, 490rwhp/474rwtq 10.83@130.6 1.59 60ft
    10.96 video
    in car vids
    10.9 runs
    Oct 2006
    I had the same trouble with the IAT's but could not figure a way to filter them properly as there is a blend with ECT's dependant on RPM. I eventually just filtered out the excessive IAT temp readings & did the rinse & repeat. Hopefully I will have my OTRCAI finished by the end of the week & my IAT's should stay a bit more sane around town.
    Oct 2004
    Consider using the A0014 table of Custom OS 3, works well in my experience for IAT temp compensation - as a multiplier to the VE table.
    A number of us have found the same as what you are probably seeing: low IAT = rich, high IAT = lean. With the VE multiplier table you can lower and raise the effective value of the VE table based on IAT.
    Andrew
    EFILive Crew
    Jan 2005
    Here's a filter I use on a fairly regular basis.
    Lifetime Member Chalky's Avatar
    Sep 2003
    Thumbs up
    Wayne:
    How is that monster running?
    Good subject. I know the tutorial covers the basics but I also know that more can be done to assure a n excellent VE tune buy disabling certain settings. It would be great if someone with more experience than me could revise that particular tutorial.
    2015 Z06 A8
    Jan 2005
    Quote Originally Posted by Chalky
    Wayne:
    What kind of revisions are you thinking of?
    The goal of the tutorial was to get the basic steps in front of the user so they can get thier feet wet tuning. It gets complicated when deciding how much detail can or should be added as it has to be proven to work in a generic sense for everybody. The more advanced we make it, the more intimidating it may become.
    But, I'm always open to suggestions/revision request.
    Senior Member NewV's Avatar
    Nov 2006
    Quote Originally Posted by TAQuickness
    The tutorial as it stands is terrific. One suggestion I have is maybe an appendix with troubleshooting tips such as 'reduced power mode' ETC settings and DFCO disable for manual transmissions. There is alot of this scattered thru out the forum as they seem to be pretty common issues. This would simply consolidate it with the tutorial and it could be referenced by the tuner if needed.
    2005 CTS-V w/tuner wannabe driver
    Apr 2006
    exactly the type of thing I'm looking for. Thanks
    Chalky the car is still a beast my wot tune is nailed down pretty good in SD just looking to polish the rest up
    10.96 video
    in car vids
    10.9 runs
    Jul 2005
    TA, dont you think that deltaTP >1%TPS is a bit harsh? i'm all for steady inputs, but in real world, most people can't feel or even dictate changes smaller than 10%TPS.
    Jun 2005
    I use a delta of 2% over 500msecs. It's a little more aggressive than the filter posted above. But, it really helps get rid of the transients. A steady foot is definitely a good thing. It helps to use the floor board hump to the right of the gas pedal too. Besides, at WOT there shouldn't be any variation in TP%.
    Keep in mind....during a VE tune, there's room to allow for a greater delta for the changes in TP%. It's the MAF tuning where you really want to narrow it down. This is because of the natural definition or depth of the tables in the PCM. To get a better grasp of this effect, try to hold a single cell for 20 seconds in a map mirroring the VE table. Then, try to do the same in a map mirroring the MAF table. The MAF tends to jump around a little easier because the natural distance from the cut-off point between each cell is smaller.
  1. Any tips for tuning a 98 turbo?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 9th, 2009, 04:54 PM
  2. new to autoVE tuning
    By noobtuner in forum Gen III V8 Specific
    Last Post: May 8th, 2008, 05:54 PM
  3. LS2 Tuning Experiences & Tips
    By oztracktuning in forum Gen IV V8 Specific
    Last Post: November 23rd, 2006, 12:45 PM
  4. AutoVE Tuning
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: September 30th, 2006, 12:48 PM
  5. Tuning w/o AutoVE
    Last Post: December 5th, 2005, 03:25 PM
