If I want to take a stock 2000 camaro 6 speed tune and use it with a custom OS 2 bar set-up, how can I do this!
It seems I can only do it with 2001 stock tune and newer.
Thanks,
Glenn
Thanks,
Glenn
Do you have Personal or Commercial edition of FlashScan. If you have Commercial you can perform a full reflash operation and upgrade to a 2002 OS. The stock 2002 Os is 12212155, and the Custom OS stream that replaces that is 0202000x (02020003 for COS3).
You can get a stock 2002 Camaro file from the site in my sig
Andrew
EFILive Crew
You might be better with OS3 it has all OS2 has plus extra stuff. So no real reason for not using OS3
2014 VF SV LS3 Maloo.
go to www.holdencrazy.com and download the Camaro 1999migratedto2002 OS. From there, you can copy any changes (with two instances of the editor open) from your current tune into the migrated 02 tune. Full flash.
This is great information guys.
Okay, so I want to start completely over, so I downloaded the 1999migratedto2002 OS.
Now I can pick the custom OS3 and I am ready to start from the beginning.
Right!
Thanks again,
Glenn
0202000x is the Custom OS stream for the stock OS you have now (12212156) in case you hadn't got that far
OS3 is the way to go!!
Andrew
EFILive Crew
Thanks Andrew, the first time I did this 2 bar flash, I had a starter tune and I want to set-up my own tune starting from the beginning
So if i want to use OS3, I just input 03 at the end of my custom OS stream.
Am I on the right track here?
Once again, you guys on this site are extremely helpful.
Thanks,
Glenn
Okay, I found the 02020003 tune in the custom OS file.
I think I am headedin the right direction. I will keep you guys posted.
Thanks,
GLenn
