Results 1 to 8 of 8
Thread: trans shift pionts?
    Junior Member JODAGR's Avatar
    Dec 2006
    Default trans shift points?
    I have a (01)2500 silverado with 6.0 I'm trying to move the shift points down at WOT because of a rev limiter I set at 4500rpm I changed parameters D0910-D0912 for 1>2 and D0915-D0917 for 2>3 also I changed D0940-D0952 And still I cant get the shift points for WOT below the rev limiter .Any help will be great.
    Aug 2004
    This is the Diesel section. For the trans to shift, it has to hit 2 perameters, Miles per hour Then / Or Engine RPM. Both conditions have to be met before Soloniod actuation will be made.
    Also make sure the following are met:
    D0925-D0927 < D0910-D0912
    D0930-D0932 < D0915-D0917
    (about 10 mph difference is good).
    Edit: see correction (sorry I type badly)
    Dec 2006
    Hey thank you for the help ,I tried it this morning and it all works great. Sorry about putting it in the diesel section . Were should it go?
    I'll move it to Petrol/Gas->General...
    Why did you set the rev limiter at 4500??
    Dec 2006
    Company trucks,enough said right? Hey thanks joecar for moving it. I'm such a rookie!
    No worries...
    See post #3 again, I corrected my stupid typo..., but you figured it out already.
    me-> <-typos
  1. trans won't shift at WOT
    By lilicedout24 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 4th, 2010, 10:54 AM
  2. G8 trans
    By minytrker in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: October 8th, 2008, 10:59 AM
  3. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  4. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
  5. trans shift pionts?
    By JODAGR in forum General (Petrol, Gas, Ethanol)
    Last Post: January 5th, 2007, 09:15 AM
