From an ealier post:Originally Posted by Big Kahuna
But, definately try the set screw first and go from there.Originally Posted by TAQuickness
Ok after much screwing (pun intended) around with the throttle stop screw and some alterations to make the T/B blade hole smaller. I am still seeing the IAC steps around the 19-24 mark. As soon as the cooling fans kick in the steps go to 34ish, so Im making some progress.Originally Posted by TAQuickness
Ive noticed that with my T/B screw adjusted fully closed, the steps decrease, if I open it slightly (1 turn) the steps increase which suggests to me that either the balde is past 45 degrees when fully closed and starting to open again, or the blade itself isnt of the best machine work.
I've gone from T/B blade hole size of 4.5mm down to 3mm. I'm going to close it fully this morning and do some more testing. Ive notice if I place my finger over the hole to close it off, my IAC steps are in the mid 30's.
What do I make of all this????????????????????????
HX Ute.
You have a weird throttle body
But it sounds like you are on the right path
2014 VF SV LS3 Maloo.
Given the T/B is from STARR Performance, anyhting is possible. The king of rip off.Originally Posted by ringram
Ive had it for many years so I will persist with closing the hole up and if that sucks, then Ill refit my stock t/b and start all over again.
But to answer one of my question still unanswered. To increase the iat steps, do you increase the desired airflow table?
HX Ute.
Sounds like you have answered your own question...The hole is letting in too much air. By the way, how are you "making" these holes smaller? My untouched 80mm BBK has no hole, my stock 75mm Fbody had a little hole. With full control of the IAC valve via the cal I don't think there is a real need for a hole for most applications.
www.efialchemy.com
www.greatamericancarwar.com
Thats intersting Doc. I didnt know the BBK's had no hole.Originally Posted by Doc
No hole it is then.
HX Ute.
Well as my predictions and logging suggested. After filling the hole, the car idles magically at 850 with iac counts of 30-35.
Bout time.
HX Ute.
I think it was chewing gum?Originally Posted by Rhino79
Man, welcome to the club. I've twisted that damn set screw so much I have carpal tunnel! IAC is hell to get right.
2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
Bronzed close.Originally Posted by Rhino79
HX Ute.
