Results 1 to 3 of 3
Thread: TPS won't go below 14%, or above 88%
    Nov 2005
    Default TPS won't go below 14%, or above 88%
    I'm still completely new to this game, so go easy on me.
    This was my first log ever, in a friends 2005 vette. I noticed while logging that the TPS % won't drop below roughly 14%, nor will it go above 88%. What's this all about?
    I tried to find a table in the tuning software to adjust how far the throttle blade would open, but didn't have any luck finding such a table. (Again, I'm completely new to this)
    If you need the log file, I could email it to ya. Just let me know.
    Thanks guys, and love the software so far.
    Austin
    Nov 2005
    Nevermind. After actually reading for 2 minutes, I think I found my answer in another thread:
    Quote Originally Posted by DrX
    Did it ever log 100%. Does the blade open 100% visually if you look at it while the pedal is held down. I have read that SAE.TP won't go past 88% on these vehicles as it is referring to a % of 5V rather than physical TP. GM.ETCTP is the PID to log.
    I'm gonna give this a try. Will report back with details.
    Oct 2005
    It still won't drop to 0 though as the throttle blade is regulating the idle airflow on ETC vehicles(i.e. there is no IAC motor). But you should see much lower than 14% at idle.
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
