I flashed in the '02 OS and put the SD for autove tune in the car and went to drive home from my fiancee's dad's house and the car didn't even wanna idle or run, it was breakin up driving down the road, as soon as I gave it any gas, it went stupid rich, 10's and 11's, and as soon as I let off it pegged lean!!! I had to pull over and throw the regular tune in and reconnect the maf to make it home!! Another thing, i'm throwing a bunch of codes already with the new os.
Anyone know what these are:
P0106 "Manifold Absolute Pressure (MAP) Sensor Performance" EPA Pending ($10) "Powertrain Control Module (PCM)"
P0106 "Manifold Absolute Pressure (MAP) Sensor Performance" C ($10) "Powertrain Control Module (PCM)"
C0245 "EBCM Control Valve Circuit" H ($28) "Traction Control System (TCS) or Electronic Brake Control Module (EBCM)"
U1000 "Class 2 Data Link" HC ($60) "Instrument Panel Cluster (IPC)"
I'm assuming the traction control one is cuz I never had traction control or cruise control or any of that in the car, it was a stripper no option car from the factory, has roll up windows and no power locks too, haha. Also, the SES light was flashing instead of goin solid, dunno what that's about, always thought that meant emmissions or misfire (had it happen when I bent pushrods a long time ago on the stock motor). But any help is definately appreciated, thanks!!! Don't know how the hell i'm gonna go and log to get the car dialed in if I can't even get it to run.
Also, for some reason the pid for the calcben for the wideband doesn't work, it's x'd and it won't read, says invalid or something, how do I fix that?
