Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Logging on a 02 LL8 problems
  1. #21
    Quote Originally Posted by WanaDmxsub
    Blacky
    That didn't work either. 16 channels for a count of 24.
    Hmm, right now I'm out of ideas. I will see if I can come up with anything else useful.
    Maybe try logging on an LS1, if you have access to one. That will tell whether the unit is faulty or if some incompatibility has crept into the software for duramax and other non-LS1 controllers.
    Obviously you'd need to program a different set of LS1 PIDs.
  2. #22
    Sep 2007
    Just for your info, the green LOG light is showing and it looks like it is logging data but the only "data" that is being received by FlashScan is the error message from the PCM saying "you've requested too many channels". The BB logger is programmed to keep retrying on an error until the user presses the stop logging button.
    Is there a way that I could see that or other messages being sent back from the PCM.
    '04 C2500HD D/A LS EC SB, Chrome Nerf bars, Grandson's "throne", Prodigy, Weatherflector, Breezer, A.R.E. Z w/accordion boot, Bedrug, H2's, Bilsteins, Predator, VR Straps, Bowtie Flag, Mag-Hytec's, SPA Boost/EGT, Katless 4", BigMouth Grille, SD Manifold, SCIII .50 Hot Rod Allison/TTS triple, Airlift Superduty bags, Banks Bighead, Fugly '06 Mirrors, Van Aaken 230, Garvin Wilderness Rack, EFILive
  3. #23
    No, because there is no display on FlashScan V1, so there is no obvious way to alert the user to an error condition. (V2 will change that with its ability to display messages on its built in screen).
    One way to tell if the logging is working is to watch the MEM LED which will illuminate as soon as the first frame of data is saved into the BB memory. If it illuminates then data is getting saved. If it does not illuminate then only errors are being returned.
  1. LMM logging Problems
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 25th, 2009, 01:08 PM
  2. Problems with AEM Uego serial logging....
    By BlackGMC in forum FlashScan V2 BB Logging
    Last Post: July 19th, 2008, 04:53 PM
  3. 7.3.0 Patch 10 Logging Problems?
    By BowlingSS in forum General
    Last Post: October 10th, 2005, 09:40 PM
  4. Problems with BlackBox Logging with V7.1.7
    By 02Z06 in forum General
    Last Post: February 2nd, 2005, 09:57 PM
