Results 1 to 5 of 5
Thread: Flash problems
    Default Flash problems
    I posted before that I couldn't full flash a computer due to the lack of a serial #. Well, I updated my software to fix this.Now I can't partial flash because it says to full flash for a serial #. Then when we try to full flash it won't because it can not determine the appropiate EE Prom memory structure
    Before the upgrade it would atleast partial flash
    Slowhawk, I sent Paul a pm.
    I presume this is using V1 Flashscan...?
    What vehicle is the PCM in...?
    What was the previous version of software...?
    What is the current version of software...?
    V2
    7.3 ??? the latest,downloaded last weekend.
    2002 HD truck. GMC ,6.0 4wd.
    PCM came from Jes at Wait for me
    No vin
    no body #
    Another shop had the truck first.
    Aug 2004
    email me the file, Ill check it out and fix it for you.
    Quote Originally Posted by wait4me
    E-mailed last night
  1. Serious problems with full flash for DSP5
    By gman in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 18th, 2010, 04:37 AM
  2. Flash Scan V2 problems
    By loafycleetus in forum FlashScan V2
    Last Post: April 20th, 2009, 02:51 AM
  3. 2005 colorado I5 flash problems
    By nonnieselman in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: July 9th, 2008, 05:00 PM
  4. Problems with idle after AutoVE flash (again)
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 03:17 PM
  5. has anyone had vtd problems after bench flash of costom os
    By madprof01 in forum Custom Operating Systems
    Last Post: April 26th, 2006, 01:30 AM
