Results 1 to 6 of 6
Thread: Question about open loop mode
    Nov 2005
    Default Question about open loop mode
    I've heard (I think) about people tuning in open loop mode. Which, IIRC from my user manuals, means that the O2 sensors are not used, mostly during warm up times.
    My question is. Can you tune solely in open loop mode, eliminating the O2's completely? This would allow you to run leaded race fuel at your leisure, correct?
    Would you be required to go SD if you went this route?
    Thanks for helping out the nOOb.
    Aug 2005
    Yes, you could run OL all the time. I currently am with my truck.
    You would not need to be in SD, although many people opt to go that route.
    Jan 2005
    I run OLSD full time (for about 2 years now). Can't seem to get reliable response from my NB's to revert back to CL.
    Oct 2004
    Me to, OLSD for 2 years! Last time I went CL it was a bit rough as well, maybe dead O2's. Not going to replace them of course. Can you turn them off, so you could say command 14.63:1 in B3647 and not be in Semi-Open Loop? Never thought about that before..
    Andrew
    EFILive Crew
    Ditto, OLSD... never have to think about replacing a failed O2/MAF sensor.
    May 2006
    Glad to see you here Austin. Hows the car coming along?
  1. Returning and starting tuning in Semi open loop SD mode
    By nitrorocket in forum Custom Operating Systems
    Last Post: July 30th, 2006, 01:56 PM
  2. Today I tested the difference between SD and MAF mode both in open loop
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2006, 01:36 AM
  3. Open/closed loop question
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 8th, 2006, 11:05 AM
  4. Commanded Open Loop AFR (B3605) Question?
    By fyi in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 09:54 AM
  5. dfco and lean cruise in OS3 semi open loop mode
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2005, 09:02 AM
