Are you saying you can remove your PCM without touching your airbox?
What airbox have you got there GMPX? Is that from STARR?
I have a G & D OTRCAI and all I have to move is the coolant bottle. Getting the wire through the firewall was a PITA for me!! I have the 4 gauge power cables for the amps going through there as well as some alarm stuff. Then it was filled with silicon so it didn't leak. There was no way in hell that either the USB or RoadRunner end was going through there...
Solution: get another USB cable and RoadRunner end connection, chop off one of the USB ends, push through small hole, rewire/solder the new connection. Best of all.. It still works
Andrew
EFILive Crew
