Results 1 to 7 of 7
Thread: searching doesn't like me much... 2.73's to 3.42's
    Default searching doesn't like me much... 2.73's to 3.42's
    I bang off the rev limiter going from 1st to 2nd really bad, I actually let off the gas pedal when it's shifting so it will go...
    I have the proper gear settings so speedo reads correctly, what else do I need to change?
    [/insert funny quote here]
    Oct 2004
    When changing the gear ratio there will have been an option to recalculate the shift point tables for the transmission.
    Under 'Speedometer->Parameters' where you entered the new ratio there is an 'Adjust' button in the 'Transmission shift point adjustment' section. That is where you need to do it
    If you didn't do this probably the easiest thing to do is copy the values back from your original tune, save it as some other file name. Then open this new file, make the ratio change again, but this time also do the shift point adjustments.
    Andrew
    EFILive Crew
    well I didn't want to respond to this because I didn't want to look like a dumbass... but...
    I had my laptop fail and I lost the original tune for my vehicle... so is it possible to go in and set the gear back to 2.73 save without doing the transmission adjust, then change it back to 3.23 and apply the transmission adjust?
    why does that question just sound dumb in my head?
    :poke:
    Quote Originally Posted by Koncrete
    Koncrete,
    No problem, "stuff" happens to everyone...
    Yes, go ahead and do that, but I would close the file after setting 2.73, make a copy of this file, and then reopen the original to do 3.23 and the adjust; that way you have a copy in case things go bad (we're dealing with computers... ).
    Joe
    cool, I will give it a shot at lunch... hopefully I wont kill it... I probably wont be able to test it for a couple of days because we just got our first snowfall here in DC...
    Oct 2004
    You may also be able to find a stock tune in the tune repository to compare to?
    Andrew
    EFILive Crew
  1. My AutoVE doesn't look right??
    By Mr. P. in forum Gen III V8 Specific
    Last Post: December 2nd, 2009, 07:01 AM
  2. searching 4wd 4L60E T42 .tun file OS:24235341
    By harascho in forum Gen IV V8 Specific
    Last Post: January 4th, 2009, 01:33 AM
  3. searching on how to get started-
    By 427 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 21st, 2007, 01:35 PM
  4. Why doesn't SAE.MAP not work? (2-bar)
    By Alvin in forum Custom Operating Systems
    Last Post: October 27th, 2006, 06:07 PM
