Thread: 4L80E Stock file with 01250003 OS?
    May 2011
    Default 4L80E Stock file with 01250003 OS?
    I've been searching for a 4L80E stock file on OS 01250003 for a while and so far no luck. I found a few old threads that had some info, but no 4L80E's. Trying to finish a transmission swap on a Firebird and thought I would ask if anyone has a file archived they could maybe share. Trying to avoid a whole OS swap if I can. Thought I'd give one last try in case someone had a file. Thanks for your help in advance!
    May 2011
    Still looking for a stock tune file with OS 01250003 equipped with a 4L80E. Thanks in advance!
    You cannot segment swap a Custom OS in EFILive (at least last I checked, and I doubt this would change). Last update to the LS1 COS documentation was 2014.
    Take your base OS (assuming 12202088), segment swap it to 4L80E, then do the upgrade to COS 01250003.
    If you don't have the stock file or can't find an 80E segment for OS 12202088, it may be simpler to go to the 02 OS 12212156 (with COS 02020003 or 02020005) as manual/4L60E/4L80E transmission segments are readily available.
    May 2011
    Thanks for the info ScarabEpic! Appreciate the help!
    +1 on what Eric said.
    May 2011
    I downloaded OS 12212156 and updated the calibrations and segment swap. I haven't loaded 02020003 COS to the vehicle yet, but plan to in the next week or so. Then I'll throw the calibrations at it and see if there's joy. Thanks again guys! ...and thanks for deleting that scammer post in this thread also. Hopefully that guy's banned!
  1. need B9021 for 01250003
    By BLK02WS6 in forum CAX Files
    Last Post: December 10th, 2019, 11:04 AM
  2. looking for 4l80e stock tune
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 6th, 2018, 05:57 AM
  3. Stock 8.1ltr w/4L80E
    By GAMEOVER in forum Gen III V8 Specific
    Last Post: February 22nd, 2011, 11:58 AM
  4. Looking for a stock T42 4L80E cal
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 17th, 2010, 02:59 PM
  5. {B3647} in 01250003
    By SS2win in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 02:32 PM
