I thought I was doin everything right and starting to make progress, but I got home from work tonight and started the car and started the scan tool with the desired airflow map to try and get my idle better and let it sit for quite a few minutes tryin to let it warm up and couldn't get past 80 degrees Celcius column and it started at 20 degrees celcius column, so I shut her off, put the numbers in the desired airflow table and then everything after 80 degrees celcius I matched to the 80 degree table, well, I flashed it in and started her up and the idle was hangin high, and would hang high everytime I reved it and then slowly come down, but this wasn't the main problem, I went to take it for a ride and it started popping really bad out the exhaust, I was like wtf!!! So I flashed the last tune in that worked and same shit, so I just pulled all the plugs and every single plug was fouled really badly!!! So I dunno what i'm doing wrong here, but something is up!!! If anyone on here that knows what they are doin with tuning these cars is anywhere near Florida and could help me learn how to tune my car, I would really appreciate it!!! I learn a lot better with hands on teaching than reading and I don't know where the hell i'm goin wrong and would like to finally get my car tuned in correctly instead of just gettin by! I wanna pull the most out of my car that I can! I will definately travel a bit if ur willin to help me, thanks guys!!!
