Results 1 to 10 of 11
Thread: help
    Aug 2006
    Default help
    i am not sure were to post this at, but i should be getting my efi live mon/tue and want to just get a basic idea of how to set it up. basically i copy the latest update from the website and plug it into the truck. or is there something i am missing. also i purchased it from mcrat and he said i need to send a copy of my stock file to him how do i go about that. i also read that i need to always keep a copy of my stock file saved on several computers. thanks for the help and sorry i'm sure this is the same stuff you hear over and oever, i just want to hear it from a real person and have direct answers.
    Oct 2004
    If you got the download form the downloads page on www.efilive.com it will be out of date (we will update that shortly). Download from HERE
    Install this build of the software, then when you get your product you'll need to install the latest drivers - download then HERE. Then you enter your license details and you're away.
    To read the tune out of your car/truck simply connect everything to your vehicle and the using the Tune Tool use the 'Flash->Read PCM calibrations' option.
    It will probably make more sense when you have everything in front of you. There is some pretty good documentation to.
    Andrew
    EFILive Crew
    Aug 2006
    ok i just got my stuff and i believe i have all the new stuff added. basically i just plug this into my truck i am good to go!
    Oct 2004
    Pretty much. Load the software and install the drivers. Connect to car and you should be away.
    Andrew
    EFILive Crew
    Aug 2006
    well i thought i had everything and i just hooked it up to the truck and no go. i am uninstalling and downlaoding all the stuff right off the links above. but i just double click the tuning tool and it should work right. that is with the v2 plugged into the computer and cable to v2 right???
    Oct 2004
    Did you load the drivers for the FlashScan device? There instructions in the 'C:\Program Files\EFILive\V7\Docs\FlashScan V2' folder for different operating systems.
    Andrew
    EFILive Crew
    Aug 2006
    alright i was able to connect and tried to copy and at the very end it said bad bin and that i need to email it to efi live! what did i do, everything was going great and then at the end it did not work!
    Aug 2006
    i am so lost right now not sure if it is just what i am doing or what? please any help to get me going would be great thanks much, steve
    Oct 2004
    What is the vehicle. Looking at your handle it is a red WS6, but you shouldn't have issues with that. Send the downloaded tune file to support at efilive dot com.
    Andrew
    EFILive Crew
    Also, can you post some screen shots of what you're doing...
    see post #2 of this: showthread.php?t=3064
