Results 1 to 10 of 11
Thread: Installing new firmware
    Jan 2007
    Default Installing new firmware
    First post here. Great product. Slowly but surely learning to use this tool. Just need a little help with upgrading my firmware. I've got the V2 flashscan and just installed the lasted version. I'm trying to update the firmware and I get a "no reply from flashscan" error. What am I doing wrong? My cables are plugged into my laptop.
    Thanks.
    Oct 2004
    This is the process:
    1) Unplug the RJ45 (OBDII) connection and the USB connector from the V2 interface.
    2) With the USB cable connected to your laptop, hold down the CTRL key on the V2 interface while you plug in the USB cable to the V2 interface. You should notice that some of the LEDs on the V2 now toggle side to side.
    3) Now open the Firmware Utility
    4) In the 'Update FlashScan V2:' section of the program click on the '...' button to locate the firmware file
    5) Once you have located the file (above step) click on the 'Program' button. Sometimes the numbers do not go all the way - this is not a problem, it still continues in the background.
    6) The FlashScan device will reboot on completion and the update is complete.
    Andrew
    EFILive Crew
    Jan 2007
    Thank you! That did the trick.
    Jan 2005
    Welcome to the forum Black346.
    Member pkincy's Avatar
    Sep 2003
    I presume Ver 5.2 is the update from the Ver 4.7 the early V2s shipped with.
    Perry
    Oct 2004
    Thats correct. Those numbers will continue to increment as updates to the firmware are made/released
    Andrew
    EFILive Crew
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Where the hell is the Firmware Utility? My lights are toggling. Where is step 3 found. WHat do I click or run!
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Aug 2004
    lol, you have to go to: C://program files/EFIlive/V7 It will be in there.
    Apr 2004
    Clicked on file.
    I received
    EFILive cannot load the file... EFILIVE_Firmware.exe
    The binary image is not 512kb, 1Mb nor 2Mb
    Well shit, the 2nd try seems to be at least giving it a "go".
    Apr 2004
    Sigh...
    Looks like it made it that time. Back to the car for another attempt.
  1. Installing the V7.5 Software
    Last Post: February 9th, 2021, 11:28 AM
  2. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  3. Help w/ installing driver for Lc-1
    By 99TransAmls16spd in forum General
    Last Post: June 24th, 2008, 06:44 AM
  4. Installing wbo2
    By Adam Calley in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2008, 11:20 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
