Can't get my GTO to read the scan part of EFI live. I am a newbie and don't have a license to reprogram the computer in it yet. Should'nt it read the basics like mph,rpm,tp?
02' T/A convertable,ram air,Procharger-D1SC,dual intercooled,Patriot stage 2 heads,small comp cam,childs & albert rods,forged pistons,fast ls6 intake,90mm throttle body,NOS,TH400,2500stall,trans brake,moser rear w/4.10's,tubeler upper & lower A-arms,QA1 raceing shocks,tubeler drive shaft loops,subframe connecters,OK to much to list.There is more!! Dynoed @ 520hp & 580tq. at the tires without nitrous.6.9@93mph 1.7 60ft. in 1/8.
Hawk,
Try these steps in order...
After connecting to vehicle, validate pids.
Then make sure the pids on the PIDs tab are highlighted (not crossed/greyed out).
Then make sure your gauges/charts on the Dash tab are configured for those pids (not crossed out).
Then press the yellow (monitor) or red (record) button on the bottom of the scan tool.
Now look at the Data tab and see if the data values are coming in (e.g. do RPM and MAP make sense); then check these on the Dash tab.
Joe
Thanks man. Might take me a while to understand what everything stands for though.
Don't worry. If you stare at it long enough, it all starts to make sense
I see you have a 02 T/A, so you dont need V2 for that car, but for the GTO you do need FlashScan V2 as only it can read the E40 ECM. I dont know if you have V2 or not, but if you are trying to scan your E40 with V1 it isnt going to work.
Yea it all comes up (the dashboard) and works good in the trans am, but i plug it into my gto the dashboard does not work. I don't exactly know what version i have but it's pretty new. About 5-6 months ago. If i do need the V2 how do i get it?Originally Posted by ScarabEpic22
I do notice that it has the electric throttle option in the calibraton file. I just looked i have the version 7.3
V1 and V2 are hardware designations.
Pictures of V1 and V2
Oh i see. Can i get something that will let me use my laptop?
you can use your laptop with both, but only the V2 cable will talk to your goat
