Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: LC-1 heater power question...
    Tex,
    When playing/experimenting with it, be very careful to not short the yellow or brown wires to anything (power, ground, each other)...
    failing to observe this will damage the DAC inside the LC-1 (requires sending back to Klaus for repair).
    the only good place they can connect to is either NBO2 signal hi or FlashScan analog input.
    Joe
    Senior Member ToplessTexan's Avatar
    Sep 2003
    The only rule I try to follow when messing with hardware is don't let the smoke out. Actually, I'm used to working with delicate/sensitive gadgets. At least the LC-1 won't hurt me if I'm careless.
    Sep 2003
    NAH, thanks. Nice link.
    Talking
    Quote Originally Posted by ToplessTexan
    The LC-1 won't hurt you unless you grab it by the end of the cable and swing violently over your head... then it might poke your eye out...
    Oct 2006
    You're welcome mate.
    2004 Monaro CV8 - 80mm BBK throttle body - 42lb Injectors - 1.8 Rockers - CAPA Long-Tube Headers- SLP Exhaust - Vortech Centrifugal S/C @ 7PSI- CAPA Intercooler - Bilstein Shocks - Wilwood 6-Pot/4-Pot Brakes - TyreWatch Monitoring - LC-1 Wideband - KAAZ Diff - Racelogic - 480RWHP
  1. Intake heater delete
    By JustinD in forum Duramax LB7
    Last Post: June 1st, 2010, 05:22 AM
  2. Intake heater
    By Jetmech in forum Duramax LB7
    Last Post: October 21st, 2009, 03:37 PM
  3. Heater blower quit working
    By 69camaro5speed in forum Gen III V8 Specific
    Last Post: November 8th, 2008, 01:09 PM
  4. Replies: 3
    Last Post: October 6th, 2005, 06:21 PM
