Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Upgrade to Commercial Version
    Oct 2004
    Default Upgrade to Commercial Version
    I just noticed that the upgrade to the Commercial version of FlashScan has been made available on the Online Store.
    It mentions 2 PCM licenses, however I currently have 4 PCM licenses for FlashScan Personal (from the one month introductory offer).
    How will this upgrade work, will I still have 4 PCM licenses for the US$150
    Cheers.
    Default Re: Upgrade to Commercial Version
    Quote Originally Posted by Tordne
    Cheers.
    Yes, the upgrade is an email code that you enter into the FlashScan cable. Once it sees the correct code, the FlashScan cable reprograms itself to be a Commercial cable. Any PCM licenses will remain unchanged.
    Oct 2003
    Cheers.
    How soon can I upgrade?? TIA.
    joel
    Quote Originally Posted by bink
    joel
    It is available on our online store now - look in the upgrades section.
    http://store.efilive.com/index.asp?P...PROD&ProdID=23
    The web store does not ask you for your FlashScan serial number or license key (we'll fix it asap). So when you are ordering just add those details to the notes section.
    Sep 2003
    Looks like i need to put the computer case purchase to the side for an upgrade this weekend
    Oct 2003
    joel
    Thank you.
    I used the link.....
    joel
    Jul 2004
    Corrected.
    Jun 2004
    Cheers.
    I want to verify I am reading this correct. The upgrade "includes" 2 PCM licences with the commerial designation to allow the full flash and ETC cals.
    So, if I have 4 current available licenses, then the upgrade will advance that to 6, and be commerial?
    Loyde
    Oct 2004
    I think what will actually happen is that you (and I) will retain the 4 PCM licenses that we currently have, but gain the full re-flash and additional functionality of the Commercial version.
    I think the confusion about the 2 PCM licenses may just have come about because the product description of the upgrade product is identical to the full product.
    Cheers.
    Cheers.
    That's what I think (that you'll still have 4 licenses)...
    (applying logical reasoning: if you had purchased n licenses at $100.00 each, and now you upgrade to commercial, it makes no sense to end up with fewer licenses than prior to upgrading).
  1. V1 Commercial to V2 Commercial Upgrade
    By ls698ta in forum FlashScan V1
    Last Post: November 29th, 2010, 08:25 AM
  2. Can v1 commercial version fully program a new pcm?
    By azzhauler in forum FlashScan V1
    Last Post: May 17th, 2007, 03:56 PM
  3. Do you have to have commercial version to do the Auto VE tuning??
    By BrianC98Z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 9th, 2006, 01:44 PM
  4. LLY Commercial Upgrade
    By Trippin in forum Duramax LLY
    Last Post: January 28th, 2006, 09:59 AM
  5. Commercial upgrade
    By jfpilla in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2005, 12:59 PM
