Results 1 to 5 of 5
Thread: Fuel Trims are 0
    Lifetime Member Rhino79's Avatar
    Jul 2006
    Default Fuel Trims are 0
    I was tuning a 99 Firehawk with LT's, ORY, Sweet Thunder Mufflers, SLP lid, and a 4000 Converter. I upgraded the OS to the 2002 system and when I started logging, the LTFT's and STFT's were on 0 and they stayed there. So I looked at the O2 mv's, one stayed at ~.800 and the other ~.440. Niether switched at all. As far as I know they are the originals, and the car has 75,000 miles. Do you guys think that the O2's are shot and causing the fuel trims to be inactive?
    Thanks Ryan
    Oct 2004
    Are you in open loop? If so trimming doesn't happen
    Andrew
    EFILive Crew
    Jan 2005
    if you are getting DTC's for the O2's, you in open loop and you're trims would likely be 0.
    Senior Member NewV's Avatar
    Nov 2006
    My O2 mv's are constantly changing as they show to the 3rd decimel point. This is in OL or CL provided they are plugged in.
    2005 CTS-V w/tuner wannabe driver
    Jul 2006
    Quote Originally Posted by TAQuickness
    O.k so with a bad o2(s), it puts the pcm in OL then? That would explain my problem then cause it had a insufficent activity code for the passenger side O2. Awesome, I've looked through the tune about 4 times last night and today comparing tables to other tunes of the same OS, and I couldn't find anythhing putting me in OL. All the CL enablers were right on with the factory tune. Must be the bad O2 then...thanks!
  1. Why negative fuel trims after autoVE
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: July 16th, 2010, 11:14 PM
  2. E38 fuel trims
    By minytrker in forum Gen IV V8 Specific
    Last Post: July 2nd, 2010, 02:44 PM
  3. Fuel Trims for 12.5 AFR with LC1
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2010, 04:25 PM
  4. Long Term fuel Trims..
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 25th, 2009, 04:23 PM
  5. HELP fuel trims and AFR all over the place?
    By warscout2 in forum Gen III V8 Specific
    Last Post: January 30th, 2008, 11:31 PM
