Any one know how to convert EQ ratio to AFR..how is EQ compared to lambda..i know how to convert lambda to AFR.... .88 x 14.64 = 12.88 AFR
I know 1.00 EQ is 14.63 but but is 1.13 EQ? whats the formula?
I'm an idiot..i was tryin to be over complicated.. 14.63/12.8=1.142 EQ Ratio
A made a spreadsheet that does EQ to AFR - much easier on the brain
Andrew
EFILive Crew
The formula:
EQ = 14.63 / AFR = 1 / Lambda
or
Lambda = AFR / 14.63 = 1 / EQ
IF you want to be exactly spot on the 14.63 value above should be whatever value you've got in EFILIVE for B3601 "Ratio of Air to Fuel for Stoichiometry"Originally Posted by joecar
Chassis by Holden
Engine by Chev
PCM modified by Flashscan
Cam by Comp Cams
