Results 1 to 7 of 7
Thread: Any amd64 drivers available for vista etc?
    Oct 2005
    Default Any amd64 drivers available for vista etc?
    Just wondering if I need specific flashscan drivers or the generic FT ones work? Which then begs the question are there any 64bit ftdi d2xx drivers?
    2014 VF SV LS3 Maloo.
    Oct 2005
    Ok found this link http://www.ftdichip.com/Drivers/CDM/...0.00%20x64.zip
    Not sure if they are signed or not, they look like they may be. Cool. Will play later..
    Oct 2004
    Not sure if they will work/recognise FlashScan.
    Andrew
    EFILive Crew
    Oct 2005
    Good, thats what I want to hear
    Oct 2005
    Ok, maybe Im on the wrong track but I added the following info into the 64bit driver .inf
    %USB\VID_0403&PID_E4A0.DeviceDesc%=FTD2XX, USB\VID_0403&PID_E4A0
    %USB\VID_0403&PID_E4A1.DeviceDesc%=FTD2XX, USB\VID_0403&PID_E4A1
    %USB\VID_0403&PID_E4A2.DeviceDesc%=FTD2XX, USB\VID_0403&PID_E4A2
    %USB\VID_0403&PID_E4A3.DeviceDesc%=FTD2XX, USB\VID_0403&PID_E4A3
    Under the hardware section, and this under strings.
    USB\VID_0403&PID_E4A0.DeviceDesc="EFILive FlashScan FSP"
    USB\VID_0403&PID_E4A1.DeviceDesc="EFILive FlashScan V2"
    USB\VID_0403&PID_E4A2.DeviceDesc="EFILive CAN Analyzer"
    USB\VID_0403&PID_E4A3.DeviceDesc="EFILive Autocal"
    But I get the error above. Vista64 likes the drivers so the PCI ID must be ok, but says something is missing from the INF.
    Paul/Ross any ideas? Am I close or way off target? In which case are 64bit drivers an easy add or hard?
    Oct 2006
    Is there a I386 or I686 folder , don't remember which one I think it is I386 , but Windows Longhorn 64 bit required you to direct 32 bit apps to a I386 or I686 folder for them to work .
    2006 Trailblazer
    Oct 2005
    Its a proper 64bit driver, so nothing other than the drivers are there with the native 64bit files. The lines above AFAIK are to identify the device so that the OS knows to use the right drivers.
    I think there is a config line missing from the .inf file.
  1. USB drivers Pop-up
    By white01ss in forum FlashScan V2
    Last Post: June 5th, 2008, 04:40 AM
  2. Vista 64 drivers?
    By Cougar281 in forum FlashScan V2
    Last Post: November 2nd, 2007, 01:46 PM
  3. Drivers for 64bit Vista?
    By rat_rod_russell in forum General (Petrol, Gas, Ethanol)
    Last Post: August 31st, 2007, 12:32 PM
  4. How do I install the drivers for my V2 on Vista?
    By AustinL911A in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2007, 02:39 PM
  5. v3 usb drivers
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2007, 06:20 PM
