Results 1 to 8 of 8
Thread: Help please-anyone
    Member VYSSLS1's Avatar
    Dec 2005
    Default Help please-anyone
    as the title says, im trying to change my datalogging eg vn v6+8 to display MAP in VAC (kpa), not Volts, as its way to hard to work it out when tuning live memcal ecus.
    Cheers Guys
    Right click on the gauge or chart, select Gauge Properties or Chart Properties, (click the Series tab for charts), and in the Parameter selection dropdown, select the same pid but with different units; click Save and OK.
    Dec 2005
    it seems to be stuck, and wont let me change it, this is early software its v4, and only certain cars, by the looks it cant be changed.
    Oh... V4... sorry mate, I didn't see the forum section ... (need coffee )...
    My understanding is that the data stream from an OBD-I ECM contains fixed-format/pre-determined data, so if you can't select/see it then it's not in the data stream for that ECM on that vehicle.
    Dec 2005
    i thought for a minute i was going insane.
    ill just have to refer back to my trusty chart it would be nice, unless anyone else knows
    VY,
    I pm'd Paul with your question.
    Joe
    Dec 2005
    have already pm'd paul.
    Do you have the Voltage v's kPa table (or function) for the MAP sensor in the VN? If so, post the info or send it to me paul@efilive.com.
