Results 1 to 10 of 10
Thread: Tcc Pwm
    Feb 2006
    Default Tcc Pwm
    Is there a way to turn this off via the PCM? For example if I bumped up D2903 and D2904 to 100% and set D2901 to the same value as D2902. Would that effectively turn off PWM? Seeing as now the tune dictates that TCC duty cycle has to 100% and no less..
    I know this can be done mechanically with a diffrent solenoid. I am just wondering if setting these values in the tune would have the same/similar effect. I am trying to take as much slip as possiable out of the TCC when it is applied.
    I am running OS: 12212156
    EFILive newbie
    1999 Camaro SS A4 | LME Forged 347 | Yank SS4000 Stall | 226/234 Cam | Patriot LS6 Style heads 2.055 / 1.57 57cc 11.3 SCR | FLP Long tube headers
    Joel,
    I haven't played with this...
    You could try what you said, and also you could try setting all cells in D2905 to the max value.
    So bascially you want to apply the TCC to 100% in the shortest time.
    Joe
    Feb 2006
    Joel,
    Joe
    Yeah basically. I will try bumping up everything and see what it does.. I just do not want to F%$# anything up.
    EFILive newbie
    Feb 2006
    OKay, just set d2903 and d2904 to 100% and d2901 and d2902 to 900. This definately gave a nice firm TCC engagement. When scanning you no longer see the TCC duty ramp up to 100% i just instantly goes to 100%. Could it be said I have effectively eleminted PWM with tunning alone?
    GM.TCCSLIP reads less than 20 RPM or so when TPS is les than 10% anything over 10% GM.TCCSLIP start going up and got as high 700 RPM at about 30% TPS. I am going to bump up D2902 to 1000 and see if I can get rid of some of this TCC slip I keep seeing.
    EFILive newbie
    Joel, good work.
    Aug 2005
    Quote Originally Posted by Joel_SS
    Would this possibly have any effect on the rate of disengagement as well?
    Once my TCC Release points have been crossed and the PCM first commands the unlock, it takes a full second for it to actually occur (this being in 4th gear, 2000-2200 rpms), and is a KILLER with a roots supercharger, as in that second I can jump to over 6psi and on comes the lug-related knock.
    I think there may be a separate release table, which we don't have yet.
    Feb 2006
    Well I have been driving around with my TCC pressure bumped to 1000 and there is still noticable slip there.. I am proablly battling a mechanical problem here.
    EFILive newbie
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Has anyone found if there is a way to get the TCC to release quicker. It certainly can create kickdown knock.
    I notice that D2902 is set at 827 when the max possible is 1765. What is the effect of increasing this number?
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Feb 2006
    and there is still noticable slip there.. I am probably battling a mechanical problem here.
    Try the slip tests in 3rd gear and see if it still exists. You may want to enable TCC in 2nd and test that gear as well. If it exists in 3rd and not 2nd it will be a common burned 3-4 clutch.
    Al
