Results 1 to 3 of 3
Thread: EGR question
    Jan 2007
    Default EGR question
    I was looking for the table to disable the EGR valve, and all I found was B1503 and B1504. Is this the correct place to disable it, and to do so do I just throw a zero in B1504 EGR maximum temp, and a high number in B1503 EGR minimum temp? Thanks
    Mark
    _____________________________________________
    2007 LBZ CC/SB
    Dec 2005
    Try 300 for B1503 and -40 for B1504
    Jan 2007
    ok, so I had it backwards...thanks for the info
    Mark
    2007 LBZ CC/SB
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
