Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: VE Table - Interpolation SpreadSheet
    Oct 2004
    Default VE Table - Interpolation SpreadSheet
    First of all I'll start by saying that this is something that Chad (Black02SS) and I did some time ago. He keeps losing it so I'll take credit for putting it somewhere useful
    You all will have likely seen your VE Table taking on an erratic look after applying a few AutoVE BEN cycles. The principle behind this tool is that is will balance/interpolate the BEN factors from the BEN Map ad average each cell based on the factors in the surrounding cells. This is what the PCM does internally.
    The outcome is a VE table that is smoother in appearance, and with less violent transitions between cells in theory should be smoother as well.
    I've tried to use some real data to give you an example. This is not as drastic as I've seen them - most of the logs I have the BEN data is good
    Anyway, this is a VE Table with the BEN data applied directly from the Scan Tool Map:
    This is the save VE Table with the data copied from the Scan Tool Map and into the Spreadsheet, then copied and applied with the interpolated results:
Name:	Using Sheet.jpg
    As you can see there is a bit of a difference...
    I use this all the time, and I've tried it on a few people on this forum as well. I swear by it!
    You'll develop your own techniques for using it, and I'm expecting some questions... Personally I will often take the copy and fill data, then eyeball it and hand change some out there values if they occur, or pump up areas i know need more. The end result is much smoother transitions though.
    Enjoy, and I'm keen to hear feedback.
    Last of all here is the sheet
    Interpolation Spreadsheet
    Fixed Link (from post #31 below): Interpolation Spreadsheet
    Andrew
    EFILive Crew
    Looks like it works well, but is there a chance I could modify it to work with the multiple VE tables in the LL8 (Low RPM and High RPM)? Right now when I paste the data in it is all messed up as the rpm and tps points are completely different in the LL8 tunes.
    Oct 2004
    Modify as you like. I haven't seen an LL8 table(s) so I don't know it's dimensions. The purpose of the post is more to show you a technique and a tool that I think works really well.
    Because the labels in the spreadsheet are just that they don't really have to be the same as the rows in the actual tune file - if you know what I mean. The spreadsheet will perform the interpolation math on any number you paste into it.
    Andrew
    EFILive Crew
    They are a lot different, and use lots of decimals (think 42.6 tps, etc). The RPM side is in different increments too, I guess on Monday I will have to play with the table a little to get it to fit the LL8 parameters.
    Mar 2005
    Doesn't look that hard to update, if I get time I might add boost VE into that spreadsheet
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    This looks very cool. Have not used it yet, but if it can save the hand smoothing it is spectacular!
    PowrMax Performance
    100 mm PowrMAF
    Oct 2004
    Quote Originally Posted by jsttry
    Good point... I added the extra row/column to allow for the OS5 TPS VE, but not boost. I might add that and then just update the file on my server.
    Andrew
    EFILive Crew
    Oct 2004
    OK I's only been up for a few hours.. But based on your suggestion jsttry I've made a major update already
    I've added Tabs to the sheet for the B0101 Main VE Table, A0007 TPS VE Table and A0009 Boost VE Table.
    If there are any other suggestions please let me know. I'd ideally like to make amendments to this centrally so that it can be easily shared with everyone.
    Andrew
    EFILive Crew
    Andrew, good job.
    Oct 2006
    Looks good .
    Can you do the same thing in O.O.org ?(Open Office Org)
    2006 Trailblazer
  1. Spreadsheet location?
    By Aloicious in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2010, 02:09 PM
  2. Interpolation or Switching between cells ?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: June 5th, 2009, 01:12 PM
  3. Another spreadsheet thread...
    Last Post: December 21st, 2006, 08:05 AM
  4. Table Interpolation
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 25th, 2005, 11:15 PM
  5. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
