Thread: Which PIDs to monitor to get an idea on emissions?
    Nov 2003
    Default Which PIDs to monitor to get an idea on emissions?
    I am wondering which PIDS I should monitor to get an (direct or indirect)idea about my emissions - HC, Co etc. My state inspection is coming up
    again and last year I barely passed - probably because I did not bother
    to prepare my tuning carefully. New York has really tightened the limits.
    Thanks,
    Gert
    Lifetime Member emarkay's Avatar
    No OBDII scanner will do a "tailpipe sniff" - not even a TECH II.
    Without going into a dissertation on emission test methods, if your state just checks for system readiness, no MIL, and a decent visual inspection, most well maintained and minorly modified cars will pass.
    However if there is actual monitoring of the exhaust, (especially beyond just an idle check) you're going to have to be real careful how far from OEM you take your registered (on road) vehicle.
    The EPA has mandated OBDII systyem to warn the driver of possible emissions faults, and to aid in diagnosing these faults. There are ways to modify and enhance the cars without causing an EPA OBDII fault. However a idle, part throttle and full throttle tailpipe test is "the horse's mouth" and can't be fudged!
    What are the new specs? - go to your state's Pollution Control website and find out what your model year limits are, if it's a OBD/MIL test, a dynamometer test or what. Then you will know what you are up against.
    Remembe a warm, mostly stock, and well maintained car with no MIL will usually pass even the toughest "smog check"... good luck!
    Early EFILive V5 user - Upgraded from AutoTap for DOS!
    2000 Chevrolet Camaro Z28, A4 - For occasional day trips...
    1984 Chevrolet Caprice Classic - For the family...
    1989 Honda VTR250 - For me and me only...
    Nov 2003
    The test is a tailpipe emmissions test. It seems to me that
    there ought to be a way to determine from the fuel flow, the engine
    temperature, engine timing and intake air and perhaps additional
    parameters (cam timing etc., cats functioning properly) an estimate
    of emissions or an indicator of some sort. Perhaps VE can be used
    in conjunction with the oxygen storgae capacity of the cats?
    Gert
    There are no PIDs or other "relayed" data that will give the following information. Now that is not to say that measurements of combustion eficiency could give the unburnt hydrocarbons amount, and a measurement of the combustion temperature will get the oxides of nitrogen amounts, but it would be a "best guess" at best...(CO2 as well as CO are produced in the combustion, and usually are not a "critical" emission check, so that's not an issue.)
    Tese data values vary greatly,and a special and expensive sensor is needed to get this data.
    Believe me if there was a way to "real time" monitor the emissions during drive, the "Smog Nazi's" would have it emplaced on the vehicles by now...
    BTW, the stored O2 in the cats is used for the reaction/reduction process and is in no way related to the "emissions" measurement.
    Oct 2003
    I would look for misfire current and misfire history. These
    are the thing that will kill you on the sniffer, the cats are
    for breaking down residual error products and not gross
    cylinder imbalance or misfired charge. If it's clean and
    the O2s are bouncing properly, and there are no system
    faults you will almost certainly pass (unless you've gone
    and changed to a non-stock cam / exhaust).
    If I still lived in a fascist state I think I would hardwire the
    AIR pump and O2 heaters for full-time power on "special
    occasions". As well as the usual; fresh oil change @ heavier
    weight, fresh air filter, maybe a top end clean the week before.
    Oil is hard to crack and will elevate your HCs if it's burning out
    of manifold (PCV) residue or ring bypass.
    Of course the obvious - but alas, the MIL would have been illuminated on the second misfire!
    AIR pump and O2 heaters are totally unnecessary once exhaust has gotten above a few hundred degrees, and turning on the AIR pump may cause undsired readings at both emission test and PCM.
    If your car is un-modded, and the MIL is out, you will pass.
    If your car is modded, to a point where the emissions are affected, aside from hiring a private garage to test your emissions to see what changes need to be made, your best bet is to run it hard (get it really hot) before the test, make sure ALL maintenance is 100%, don't give any reason for a more "intense" inspection, and hope for the best!
  1. Tire pressure monitor
    By sixltrbtr in forum Lounge
    Last Post: September 4th, 2009, 09:57 AM
  2. how to monitor boost?
    By turboolds in forum Gen III V8 Specific
    Last Post: December 5th, 2008, 04:37 AM
  3. Readiness Monitor Question
    By Duramax 6.6L in forum General (Petrol, Gas, Ethanol)
    Last Post: June 19th, 2008, 12:45 PM
  4. Best way to monitor clutch slip
    By robz in forum General
    Last Post: March 12th, 2008, 11:30 AM
  5. AFR on EFI Live not the same as on my Log Works2 Monitor
    By esco35m in forum Gen III V8 Specific
    Last Post: September 28th, 2007, 10:57 AM
