Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Vortec camshaft retard offset
    Jul 2005
    Default Vortec camshaft retard offset
    Hi gang,
    My buddy has messed with the distributor positon on his '99 Vortec, and the service manual says to connect the Tech 2 and look at the camshaft retard offset and adjust if necessary. Is there a PID in the new release for V2 to check this? I've looked and my old eyes can't see one that seems to fit the bill. Thanks for any help you can give.
    '03 GMC 1500HD
    '79 Pontiac LeMans-LQ4/4L80E
    '05 CTS-V
    Aug 2004
    not sure, Ill look into that one?
    Jul 2005
    Sorry to dredge this up, but could anyone provide a definitive answer?
    '03 GMC 1500HD
    '05 CTS-V
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by Dave_62
    anyone? I've got V1 and am wondering about this on my '96 w/ a 411 pcm. I've heard that V1 might not be able to, but V2 would be able to. any definative answer for V1?
    Jan 2007
    I was wondering the same thing the other day.
    That'd be really handy.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Nov 2007
    Quote Originally Posted by hquick
    G'day hquick, good to see some familiar folks from over on the PPE forums here.
    yeah you're telling me. and if CMP retard offset is not in V1 currently, is there any possibility of getting it in an update or something?
    I'll be doing a intake swap, distributor upgrade, cam swap, along with a couple other things all at the same time, and won't have a tech 2 around or within like 50 miles...I know people on PPE have said to just mark everything and it won't be an issue, but I'd rather be safe incase its off, and also be able to double check it as well.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Nov 2007
    Default Whoa!
    don't everybody answer all at once now....seriously though, bump!
    It should be in the latest V7.5 release here:
    http://forum.efilive.com/showthread.php?t=6646
    If you have already installed that version but still can't see the PID, let me know and I'll send you a more up to date PID set.
    The PID is called: {GM.CMPRET} and is specific to Vortec. Anoth Vortec specific PID that was recently added is {GM.KNKRET_B}
    Nov 2007
    I'm in the middle of swapping to the 411 pcm so I haven't checked yet, but will do so, I have upgraded my V1 to V7.5 so I think we'll be good as long as its also available thru the 411 pcm (with a 01-02 L31 express van file base)
    Thanks for the help Paul!
    Jan 2007
    I haven't looked yet Paul....but will it work after doing a 411 swap or will it only work with the Vortec/Black box PCM?
    I just checked and mine has an 'X' through it.
    Is it possible to have the Vortec specific pid's working with the 0411 PCM for those of us who have made the swap?
    Thanks Paul.
    Howard
    Howard
    DUCT TAPE.
  1. Problem with DTC PO342 Camshaft Position sensor circuit low
    By LSXstart in forum Gen III V8 Specific
    Last Post: December 3rd, 2010, 03:35 PM
  2. CMP retard offset signal?
    By Aloicious in forum Vortec V6/V8 Specific
    Last Post: July 2nd, 2009, 03:26 PM
  3. Wideband AFR rpm offset?
    By Highlander in forum General
    Last Post: June 15th, 2008, 01:34 PM
  4. PLX, V2 Voltage Offset - HELP!
    By JezzaB in forum Gen IV V8 Specific
    Last Post: February 16th, 2008, 03:48 PM
  5. 5.7 vortec cam retard or offset mode
    By Jimmi in forum Vortec V6/V8 Specific
    Last Post: August 25th, 2007, 12:22 AM
