Results 11 to 20 of 24
Thread: Vortec camshaft retard offset
  1. #11
    Quote Originally Posted by hquick
    I just checked and mine has an 'X' through it.
    Is it possible to have the Vortec specific pid's working with the 0411 PCM for those of us who have made the swap?
    If you have not "validated PIDs" since the new PID was added by EFILive, it will show as unsupported. All new PIDs are initially marked as unsupported, until a PID validation is completed when connected to the target PCM.
  2. #12
    Jan 2007
    Thanks again Paul.
    I'll try it out tomorrow.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  3. #13
    Aug 2006
    WOW!
    That is a Great addition for us Distributored Vortec guys.
    Just 1 more reason EFILive is the BEST tuning product on the market
  4. #14
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by Lextech
    WOW!
    yeah, you're telling me, I'm stoked!
    Thanks again Paul,
    I'll have to check and make sure it all works when the 411 is in, hopefully this week.
  5. #15
    Jan 2007
    It works.
    I guess a problem I've just discovered is mine is reading -3.63.
    Thanks again Paul for one more reason I hope to never set foot in a dealership again. This would have been the ONLY reason for me to ever do so.
    Howard
    DUCT TAPE.
  6. #16
    Jan 2007
    I just logged that PID on my way into work. I saw a max of -6.38
    I believe I just found where all my timing is disappearing to.
    Howard
    DUCT TAPE.
  7. #17
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Howard,
    Check out the inside of your Distributor cap and see if the electrical contacts are burnt out?
    When this is out of alignment the spark that jumps from the rotor button covers a greater area and tends to get a little aggressive on the contacts.
    merry Xmas
    Mick
    Rev it up, Drop the clutch, See what happens?
  8. #18
    Jan 2007
    Thanks Mick...will do.
    I just killed my battery setting the offset. Lol! start...stop...start...stop etc.
    I hope rotor and cap are OK...they're new.
    Howard
    DUCT TAPE.
  9. #19
    Jan 2007
    Does it work with EFILive whereby I can just rev to 1000 rpm after each adjustment of the dizzy to get a new reading on the CMP?
    So I don't have to turn the ignition off every time?
    I'll try it tomorrow if no one answers in the meantime.
    Howard
    DUCT TAPE.
  10. #20
    Junior Member jomobco's Avatar
    Aug 2007
    Default sorry to dig up an old thread but...
    In reading the manual on my 99 suburban 5.7 ck1500 tonight it said to definitely turn off the ignition between CMP adjustments. And to set it at Zero.
    Question: I'm trying to find an intermittent stutter and I took it to a GM dealer. He said my MAF is reading low and that my CMP was 12. He suggested setting it to minus 8. I'm assuming with my 5.7 and the 0411computer with the 2002 express van tune that it should be zero as well?
    Edit: I found out in a subsequent search +/-2
    With the CMP at -6 my MAF was 4.64 gm/sec at 5280' above sea level. With it set at 0-1 I get 3.32. 3.1 or so was what I was getting when the CMP was 12.
    Does anyone have any suggestions? It certainly hasn't helped the stutter I'm looking for.
  1. Problem with DTC PO342 Camshaft Position sensor circuit low
    By LSXstart in forum Gen III V8 Specific
    Last Post: December 3rd, 2010, 03:35 PM
  2. CMP retard offset signal?
    By Aloicious in forum Vortec V6/V8 Specific
    Last Post: July 2nd, 2009, 03:26 PM
  3. Wideband AFR rpm offset?
    By Highlander in forum General
    Last Post: June 15th, 2008, 01:34 PM
  4. PLX, V2 Voltage Offset - HELP!
    By JezzaB in forum Gen IV V8 Specific
    Last Post: February 16th, 2008, 03:48 PM
  5. 5.7 vortec cam retard or offset mode
    By Jimmi in forum Vortec V6/V8 Specific
    Last Post: August 25th, 2007, 12:22 AM
