Results 1 to 7 of 7
Thread: 4.3 cal. files?
    Junior Member JODAGR's Avatar
    Dec 2006
    Default 4.3 cal. files?
    I have the new 555 build software and I downloaded the extra cal. files and I still cant get a copy of the tune ,It keeps on bringing up an error code. Any help would be appreciated .By the way its a 2000 1500 Silverado
    Oct 2004
    When you do a read of the PCM what is the OS # shown?
    Andrew
    EFILive Crew
    Dec 2006
    Yes it is OS # 16265175.
    Oct 2004
    A calibration has not been released for that yet. Can you forward the tune file to support at efilive dot com. We can then look to add support for it (if it isn't already done).
    Andrew
    EFILive Crew
    Dec 2006
    Quote Originally Posted by Tordne
    Ok I sent it over thanks for the help.By the way there is a calibration file with the same number ,it might already be done?
    Oct 2004
    I have just forwarded the file on. It may be an OS that we haven't seen before in which case it will need a cal made for it. It may already be done but not shipped. We'll see soon
    Andrew
    EFILive Crew
    Aug 2004
    all the vortech cals are supported. You must not have put the zipped files into the correct folder. You need to move the contents of the zipped folder to c:\\Program Files\EFILive\V7\Calibrations
    The files can not be zipped when in that folder so make sure it is just the seperate files you put in to the calibrations folder. 16265175.cal is an example of the file name that needs to be in there.
  1. '09 E85 6.2L files ?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: November 29th, 2008, 10:32 AM
  2. Where are the .dtc files...?
    By joecar in forum FlashScan V2 BB Logging
    Last Post: October 20th, 2008, 01:39 PM
  3. Where did all my files go?
    By Ira in forum FlashScan V2 BB Logging
    Last Post: December 5th, 2007, 05:24 PM
  4. MAP files help
    By killaz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2006, 12:33 PM
