Results 1 to 10 of 14
Thread: Im confused
    Default Im confused
    Im tryin to figure out this SPARK table....
    There are 12 tables that have to do with spark and the Adjustment of Spark if Knock occurs..
    Where do you guys start at?
    Im tryin to get my KR down to 0 so i can do my AutoVE tune..
    Help Please!
    -Jonathan
    Jun 2005
    If you have KR, you need to determine where you have KR. Look at grams/cyl. of airflow and RPM around the time the KR occured. Then, you can reduce the timing in the appropriate table (High Octane Spark....or Low Octane Spark if your MAF is turned off) for those conditions.
    Im bone stock with a K&N intake, Gutted Cats, Magnaflow muffler, TR55 plugs, Efans. Thats it on the motor.
    Built 60E, Stock verter. Eaton LSD out back.
    But do i just adjust the High Octane Spark?
    Jun 2005
    What year car ?
    Yes, timing is commanded from the high octane spark map unless the car is in a backup mode (like speed density/no MAF).
    And also make sure it's not leaning out inducing knock.
    2000 Silverado 5.3L
    LC-1 with EFI Live V1.
    Im still learning, thats why i ask...
    I know its lean every now and again... I have a Walbro 255lph pump sittin on my dresser im goin to try to put in this weekend.. SO im holding off with the tuning till then.
    Some times i get knock sometimes i dont..... Not sure why..
    I run 93oct from Phillilps 66. Thats the only place i get it..
    Aug 2005
    Quote Originally Posted by nonnieselman
    2000 Silverado 5.3L
    As I recall from the last log I saw, you were quite a bit lean (relative to commanded) at some points. Since you have your LC-1 working now, go SD, tune that VE table and see if the knock still appears.
    Im printing out the AutoVE Turtorial right now...
    Oct 2004
    I'm just going to chime in real quick...
    Have a look at the knock as it is introduced and retarded out. The knock sensors are just tuned microphones and you will get false knock.
    Looking at the shape:
    - If KR spikes and then retards out smoothly it could have been a false knock situation.
    - If it spikes, retards out and then spikes again, sot of like saw tooth appearance then it is probably real knock.
    I also have a hate relationship for the Burst Knock system. This system is supposed to proactively remove timing when there is a change in cylinder air density to prevent knock occurring. I have experimented quite a bit with the values for the B6210 & B6212 tables and always end up 0'ing them. Every time I try and use them I get more logged KR, and the KR retard values are significantly higher
    Andrew
    EFILive Crew
    i just looked at my latest log, Its more of a Spike and then slowly goes away...
  1. Bit confused, some help?
    By hyper24 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2009, 08:41 PM
  2. New guy is confused
    By norsemanberg in forum Gen III V8 Specific
    Last Post: July 5th, 2009, 04:24 PM
  3. Confused on IFR settings
    By samh_08 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2009, 03:47 AM
  4. Confused
    By hdmax in forum General (Diesel)
    Last Post: October 21st, 2006, 08:27 AM
  5. Confused after first autotuning run
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2005, 08:47 AM
