Im working on a 98, just put in a turbo 400 and a differnt motor. Can I flash the 98 to a differnt year like you can the 99 and newer ones. I also plan on flashes it to a 6 speed since the is no electronic tranny anymore.
The PCM for the 97/98's is different as you probably know. So you can't flash in a 99+ OS at all to these :sad:
You could probably flash between 97 & 98 but probably not much point.
Andrew
EFILive Crew
Thanks thats what I figured, I was just hoping I was wrong.
