I want to flash LBZ ecm / tcm on bench , I copy/paste the following from the GM service information system
The high speed GMLAN serial data bus uses two 120 ohm terminating resistors that are in parallel with the high speed GMLAN (+) and (-) circuits. One of the resistors is internal to the glow plug control module (GPCM) and the other is internal to the engine control module (ECM).
Could the V2 communicate safely without the 2nd 120ohm resistor installed (flashing ECM) or without both 120ohm installed (flashing TCM) ?
