Results 1 to 4 of 4
Thread: LM-1 connecting to V1
    Dec 2005
    Default LM-1 connecting to V1
    How did you guys connect your LM-1 to your v1 cable? I have went through the LC-1 setup.. and setup my LM-1 according to this. But if I use the LC-1 PIDs the scan tool read 13-14 arf (with the O2 in open air) and the LM-1 reads 20.9. If I use the LM-1 PIDs is reads a flucutating 19-21 AFR.
    This sound right?
    Jun 2005
    I programed both LM1 outputs to be:
    0V=11.00AFR
    5V=16.00AFR
    Advanced - Output rate 1/3
    Then, you find the sae_generic.txt file that is in the installed root directory. Find the LM1 pids in the text file, change it so they say:
    # Innovate LM-1 WBO2
    *CLC-00-928
    V 0.0 5.0 .1 "{EXT.AD1}"
    AFR 11.0 16.0 .1 "{EXT.AD1}+11"
    *CLC-00-929
    factor 0.0 2.0 .1 "{CALC.AFR_LM11.AFR}/{GM.AFR}"
    *CLC-00-930
    V 0.0 5.0 .1 "{EXT.AD2}"
    AFR 11.0 16.0 .1 "{EXT.AD2}+11"
    *CLC-00-931
    factor 0.0 2.0 .1 "{CALC.AFR_LM12.AFR}/{GM.AFR}"
    I did that thinking I should never see AFR's above 15.5 or below 11.5. With such a short range, I don't dilute the analog output of the LM1 like the original equation does (because it divides by 2).
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Quote Originally Posted by SSpdDmon
    0V=11.00AFR
    5V=16.00AFR
    Would recommend you don't make any changes to that file and only the calcpids.txt file.
    Jun 2005
    I only change the WB portion and know that if I ever upgrade the software, I need to correct it again.
    LCC - To Blacky's point, you want to be very careful what changes you do make in here as this is a key file. The other option would be to make a custom pid in the calcpids.txt file that he mentioned.
  1. Connecting LC1 to V2
    By LSs1Power in forum FlashScan V2
    Last Post: August 6th, 2010, 10:56 AM
  2. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  3. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  4. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  5. connecting lc1 to v2
    By mr.prick in forum FlashScan V2
    Last Post: February 8th, 2007, 01:46 PM
