Results 1 to 2 of 2
Thread: DSP2 issues
    Apr 2006
    Default DSP2 issues
    I know I'm about, oh 6 months behind the power curve, but I'm finally getting around to installing and tinkering with DSP2 stuff. I'm following the pub, and on page 6 and 7 when it tells me to open the dsp2 os, then open one of my current tunes, I dont get the option to open my tune as the comparison.
    I was however able to open my tune first, then the dsp2 os. The problem then came as I could only copy segments from 'alternate calibration to current cal', not current cal to alternate. Page 8 says the window could say either, so how can you change it?
    sorry, im a noob, thanks.
    Oct 2006
    Lightbulb
    are you sure that you are using the right dsp o/s?
    c:/ my documents, EFIlive, V7, Bins, Custom O/S, then scroll down to the correct dsp2 o/s for your vehicle.
    For example my stock o/s is 15228758 so my dsp2 o/s would be: 05875801
    so open up the proper dsp2 o/s and then load the cal file you want for the stage 1 setting for comparison. then click show summary of differences and it will display differences. now left click and highlight all the calibrations that you want to update and click update, just make sure not to highlight the dsp2 calibrations.
    now for the stage 2 "dsp2" setting copy and paste the calibrations from your saved tun file that you want to use and paste in the "EFIlive Custom calibration area on the top of the calibrations window.
    email me @ autoinnovation@hotmail.com if you have any more questions.
    http://www.dailymotion.com/dmaxtuner...32ek_smokevid2
    hope this helps,
    Josh
  1. DSP2/5 Question
    By JrTuner in forum Duramax LB7
    Last Post: September 9th, 2009, 03:28 PM
  2. DSP2 enable
    By Kennedy Diesel in forum Duramax LB7
    Last Post: July 2nd, 2006, 12:39 AM
  3. Dsp2
    By Drywall1 in forum General (Diesel)
    Last Post: March 3rd, 2006, 06:39 PM
