Results 1 to 3 of 3
Thread: PE mode
    Dec 2005
    Default PE mode
    Is there a rule of thumb for entering PE mode in B3616 - for best performance/fuelmilage?
    Also can you modify this table and leave the others in this area stock assuming the PE delay is set to 0.
    Jun 2005
    Don't have the other laptop, but if this is the PE TP% Enable table...I like to drop it a little (~10%) from stock - epsecially on modded cars. It can hurt fuel economy a little. But, it can also make moderate throttle feel a little better IMO. Mainly, my goal when tuning others' cars is to keep things a little on the safe side. A little more fuel at a moderate engine load can't hurt...
    Oct 2005
    IMHO raise MAP enable to 80kpa so you dont go into PE when not underload.
    Why do you want PE when reversing up hill etc?
    So PE is only enabled when MAP is over 80kpa.
    2014 VF SV LS3 Maloo.
  1. What is fan after run mode ?
    By 2010 Bumblebee in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2010, 04:07 AM
  2. Cant get out of demo mode
    By XChris1632X in forum FlashScan V2
    Last Post: November 14th, 2008, 02:33 PM
  3. PE mode
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 22nd, 2006, 02:18 AM
  4. PE mode lag
    By Draco in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 11:21 AM
  5. Can Valet mode be used to turn SD mode off and on?
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 11:53 AM
