Results 1 to 5 of 5
Thread: "aat"
    Default "aat"
    is this measured exterior to the vehicle, or in the intake?
    Custom Tuning Services
    It's in the intake. GM service docs refer to it as IAT2.
    The other IAT sensor is the one in the MAF.
    That is what i was wondering. So it IS post CAC. Very odd it would be labled "ambient" though. That makes no sense to me at all.
    I agree, most of the LBZ docs refer to them as IAT1 and IAT2, but I did read in one diagnostic chart (can't remember which one), they had it written as "Ambient Air Sensor (IAT2)".
    It is a very interesting adjustment.
    I have logged (separate temp logging equipment) post CAC charge at up near 200 degrees. From the table it appears optimum WOT timing goes from 20 BTDC to 40 BTDC with this CAC heat soak.
    Does this make sense? I thought increasing charge temp, required timing to be retarded....
    By contrast to the LBZ, there are no provisions in the LLY tables to adjust timing for charge temp increase.
    You probably had good reason for labeling, but I think IAT1 and 2 would be much less confusing. FWIW.
  1. what table controls start up decay speed? "how fast it decays out"
    Last Post: March 20th, 2009, 12:10 AM
  2. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  3. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  4. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
