Results 1 to 7 of 7
Thread: Conversion Calculator not working correctly
    Nov 2005
    Default Conversion Calculator not working correctly
    I was messing around with the conversion calculator, specifically the temps, and noticed that it doesn't always give you the right answer. What's up with that?
    AustinL911A,
    I'll try this out, are there any specific examples you can give...?
    Joe
    Nov 2005
    1. Try taking a temperature in Kelvin, and convert it straight to Farenheit. Take note of the answer.
    2. Then Take the same temp. in Kelvin, convert it to Centigrade, and then convert that number into Farenheit.
    -The final answer for 1. and 2. should be the same. However, they are not.
    I did this:
    373.15 K --> -48.067 F
    273.15 K --> -103.622 F
    Yep, these are wrong.
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    In the unit_conversion.txt file under \Program Files\EFILive\V7\Configuration change ID line 22 to:
    0022 = °F °K * 0.55555 255.37223 N
    That will give you a very close conversion of °F to °K and vice/versa.
    Edit: This will get it closer.
    0022 = °F °K * 0.555555 255.379983 N
    I think your first choice was more accurate (why did you correct yourself- am I missing something?):
    0.555555 and 255.3722 Seems correct to me.
    Simplifying the *F to *K formula:
    K = (F-32)/1.8+273.15
    K = F/1.8 - 32/1.8 + 273.15
    K = F*0.555555 - 17.7777 + 273.15
    K = F*0.555555 - 255.3722
    Thanks to AustinL911A for finding the fault in the first place - it will be corrected in the next release.
    Sep 2003
    Too much spare time!
    I was playing around last night and some of the calculations were not close enough.
    It must have been the *0.55555 instead of *0.555555 that was throwing it off and the fact that I found something on the internet that listed Kelvin at 273.157760. I tried the new formula with *0.555555 and 255.3722 and it is close enough for me.
  1. So did Main Injection Pulse ever change up correctly....?
    By MMLMM in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 1st, 2010, 02:57 PM
  2. Analog voltage not recording correctly
    By SweetS10V8 in forum General
    Last Post: December 29th, 2009, 04:07 PM
  3. did i do this correctly?
    By hhorton in forum External A/D inputs
    Last Post: August 24th, 2009, 01:15 PM
  4. Anyone have A0014 table working correctly with F.I.???
    Last Post: October 22nd, 2007, 05:02 AM
  5. EFI not reading AFR correctly
    By billyjo in forum General (Petrol, Gas, Ethanol)
    Last Post: December 11th, 2006, 10:55 AM
