Results 1 to 3 of 3
Thread: Another Idle tuning question
    Junior Member billyjo's Avatar
    Oct 2006
    Default Another Idle tuning question
    I've done a lot of searching and reading about how to tune for idle. I've read about steps, reseting the TPS, adjusting the screw, and logging RAFIG but right at the end I discovered (or at least I think I did) that these are all for cable throttle bodies and not ETC.
    Does all of this apply to ETC as well? What are the proper steps one should follow to make sure all is well in the idle department when using ETC?
    I'm running a 2002 custom operating system 3 with a LS2 ETC and I have a manual transmission. With the key on (not running) my TPS is 19.2%. When it's cold (the colder the worse) there is quite a hesitation at idle, this goes away when it's warm. I've been able to smooth this out by increasing A0008 to 1.11 but I'm not sure that this isn't just offsetting a problem?
    Another problem I have is after I load a new tune that once it's warmed up when I come to a stop it's searching for idle. Once it's done this 4-5 times it's fine (I understand it's learning). I thought logging the RAFIG would fix this but it didn't.
    Any help is greatly appreciated.
    Bill
    72 K/5 4x4 Blazer, Radixed LQ4 with 3.2 pulley, WCCH 90mm TB, LPE GT2-3 cam, Stainless Works Headers, NV4500 5 speed, 14 bolt FF rear, Dana 60 front, 4.56 gears, detroit lockers, 4 wheel discs, Hydro brakes, full autometer gauges and more....
    Jan 2005
    ETC systems don't have an IAC, so idle speed is controlled by throttle position. IAC posiiton with key on engine not running typically is at or near wide open so there's plenty of air available at engine start. Your 19% TPS, is the equivalent of an IAC being at or near wide open.
    Logging RAFIG won't fix anything, but it will give you an insight into what you need to change to eliminate idle problems. If that doesn't work for you, look at idle air flow right after you load a new tune and after idle stabilizes. Then you can make the changes you need.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Oct 2006
    Thanks for the info dfe1 I'm going to give that a try this weekend.
    I'm still working on the hesitation when it's cold, and it's definately temp related (outside temp). I noticed yesterday while watching the wideband that it goes very lean when I let off the gas to shift when it's cold out. What would be causing it to do this only when the temp and engine are cold?
    Thanks,
    Bill
  1. 02 z06 idle question
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: May 5th, 2010, 09:00 PM
  2. Another idle question
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2009, 05:52 PM
  3. Idle/Idle Transition Tuning
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 11th, 2007, 05:10 AM
  4. Idle Tuning Question
    By BrianC98Z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2006, 02:51 AM
  5. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: July 11th, 2006, 03:58 PM
