I've done a lot of searching and reading about how to tune for idle. I've read about steps, reseting the TPS, adjusting the screw, and logging RAFIG but right at the end I discovered (or at least I think I did) that these are all for cable throttle bodies and not ETC.
Does all of this apply to ETC as well? What are the proper steps one should follow to make sure all is well in the idle department when using ETC?
I'm running a 2002 custom operating system 3 with a LS2 ETC and I have a manual transmission. With the key on (not running) my TPS is 19.2%. When it's cold (the colder the worse) there is quite a hesitation at idle, this goes away when it's warm. I've been able to smooth this out by increasing A0008 to 1.11 but I'm not sure that this isn't just offsetting a problem?
Another problem I have is after I load a new tune that once it's warmed up when I come to a stop it's searching for idle. Once it's done this 4-5 times it's fine (I understand it's learning). I thought logging the RAFIG would fix this but it didn't.
Any help is greatly appreciated.
Bill
