Results 1 to 6 of 6
Thread: Question on creating a map for b5932
    Feb 2006
    Default Question on creating a map for b5932
    I am trying to create map for b5932 and the tune tool says the colums are Oz/Cylinder GM.DYNCYLAIR_DMA And the scan tools seems to be Grams/Cylinder.. Am I missing something here?? Becasue my map does not seems to be working right.. It was only logging in three cells...
ID:	1287   Click image for larger version.
ID:	1288   Click image for larger version.
ID:	1289   Click image for larger version.
    EFILive newbie
    1999 Camaro SS A4 | LME Forged 347 | Yank SS4000 Stall | 226/234 Cam | Patriot LS6 Style heads 2.055 / 1.57 57cc 11.3 SCR | FLP Long tube headers
    Aug 2005
    Quote Originally Posted by Joel_SS
    That's just a difference in the units you have the tune tool configured for. Go to the Edit Menu, then "Configure display units". Search for that particular table and adjust the columns unit to Metric.
    Justin
    Jun 2005
    BTW, why are you trying to create a map for the base spark table? I ususally find that if you use a chart ("B" on the scanner dashboard) and log RPM's, DYNCYLAIR_DMA, and SPARK, you can manipulate that table fairly easily given it's mainly for idle.
    Feb 2006
    Quote Originally Posted by SSpdDmon
    I wanted to add a few degrees advance to help with surging when slowing down in traffic ..I was trying to figure out what part of the table I need to do that in.. So I figured if I watch where it is logging on the map when it is surging I can bump up those sections with the tune tool...
    Justin, Thanks for the tip! I am very green when it comes to this stuff..
    EFILive newbie
    Aug 2005
    You're welcome, glad to help when I can.
    Justin
    Jun 2005
    There's a neat little trick...
    If you log the PID's that the tuning software references for a given table and have that table open in the tuning software while the scanner is logging, it will highlight the current cell being referenced in blue. If you just want to see which cell it is, then you don't have to build the map.
  1. creating a script
    By SGFastMax in forum Duramax LB7
    Last Post: June 10th, 2009, 08:26 AM
  2. Creating Custom PID, NaN function available??
    By 2002_z28_six_speed in forum General
    Last Post: September 21st, 2007, 02:32 PM
  3. Creating a one column table.
    Last Post: August 5th, 2007, 09:56 AM
  4. Creating/editing macros
    By botteman in forum EFILive V4
    Last Post: June 1st, 2007, 05:56 PM
  5. creating a map formaf recalibration
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2006, 03:30 PM
