Results 1 to 10 of 17
Thread: connecting lc1 to v2
    Nov 2006
    Default connecting lc1 to v2
    is there a setting for the analog outputs that needs to be adjusted for the lc1?
    my v2 and lc1 do not show the same afr.
    the logworks shows 14.3 average and the v2 is showing 11.2 average.
    i have heard the lc1 has problems with the analog outs so i want to know
    if there are v2 settings i should look into before i start to complain about
    my lc1 for it is new.
    what should my analog voltage be?
    Jan 2005
    Dear Mr. Prick
    With a screen name like that, you've got to be a charter member of LS1tech.
    I'm not sure, but I think the problem you're having is a consequence of LC1 values not being consistent from unit to unit. I've been using an LM1 for quite a while and it will read incorrectly unless I change the values in the sae_generic.txt file in the Configurations folder. If you do a search on LC1, you should find an answer.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Mr.Prick,
    There are 2 ways to go:
    a. program the LC-1 to match the calculated pid you're using, or
    b. create a new calculated pid to match your LC-1's voltage-AFR points.
    Do you know what AFR 0V and 5V correspond to...?
    Joe
    Nov 2006
    0v=7.39afr
    5v=22.35afr
    the lc1 logworks shows the correct afr and the analog output shows an incorrect afr and the voltage is never steady, it fluctuates even without the car running.
    i am using the 2 right out of the box and the v2 has default settings for the lc1.
    If the voltage is not steady, you may have power/ground connection problems.
    Does the LED (connected between LC-1 black and white) stay on steady (after first flashing for 20s)...?
    If the LM Programmer software doesn't connect to the LC-1, check that you plugged in the terminator into SERIAL IN on the LC-1.
    Aug 2005
    Have you programmed the V2 unit with a known voltage?
    In the scan tool it is under the Flashscan menu.
    I had to do that with mine to bring it in line with the V1.
    My output is still very jagged compared to the V1, but I'm attributing that to a couple of possible causes. Output smoothing not enabled in the LC1 controller, and/or the V2 possibly has a higher sampling rate than the V1.
    Here's my comparo image:
    The important thing with my situation is that the fluctuation I see with the V2 is very consistent, yielding BEN factors that are stable within 25-30 cell counts.
    I'm still trying to find my elusive terminal plug so I can program the controller... Probably going to have to order a new one.
    Nov 2006
    my voltage shows 0v=7.39afr on the data page.
    how do i change the way the v2 translates voltage to read
    0v=22.39afr and 5v 7.35afr.
    the logworks shows my afr correctly but the v2 is showing
    the opposite voltage to afr ratio.
    Nov 2006
    i changed my lc1 to put out the correct voltage for the v2 to read rich and lean .
    but now the v2 reads slightly leaner than the lc1 is.
    what do i do to counter this?
    Jul 2004
    The classic solution is to program the LC1 to output 0.5V for all AFRs and then to put out 4.5V for all AFRs and see what the V2 reports. Then make a PID that has the line matching the reported numbers. The world of analog outputs and analog inputs is often not as perfect as it should be.
    Ira
    Nov 2006
    yes i had some ground offsets and i solved that problem , but the two still are not in sync with each other.
  1. Connecting LC1 to V2
    By LSs1Power in forum FlashScan V2
    Last Post: August 6th, 2010, 10:56 AM
  2. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  3. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  4. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
